XK K 124 tail keeps spinning
  • Azir
    • Jan 2023
    • 6
    Hello. I changed the "received set" on my K 124 because the original got damaged in a crash. Now the helicopter will not take off and keeps spinning! Plenty of power but the tail rotor does not spin fast enough to provide enough thrust to keep the helicopter from spinning. I have calibrated the Gyro with no result. Please help. Thank you.
  • Azir
    • Jan 2023
    • 6
    Yes, I’ve double checked the blade for rotation, it looks good
    • Azir
      • Jan 2023
      • 6
      Yes, checked that as well, all appears well, the propeller spins but not with much speed, hence it does not generate enough thrust. I’m guessing that there is a problem with the new receiver, but I have no way to check.
      • Azir
        • Jan 2023
        • 6
        Problem solved, bough another receiver set and tail motor cable, all of a sudden the tail rotor is spinning with full power! One of these components was defective not sure which one.
        • Azir
          • Jan 2023
          • 6
