Official RotorScale 100 Size EC135 Gyro Stabilized Helicopter RTF Thread
    • 8231
    EC135 100 Size Gyro Stabilized Helicopter - RTF from RotorScale - RSH1009-001
    Take to the skies within minutes of your RotorScale EC135 100 Size Gyro Stabilized Helicopter - RTF arriving at your home. This affordable, quiet, and well-supported model is ideal for beginners and more experienced pilots alike, as it comes with all necessary components and can be used in confined environments with minimal wind. Its LED display also makes it easy to monitor the flight battery's charge level with the press of a button.
    Overall, the RotorScale EC135 is ideal for pilots looking for a lot of value in a convenient, "everyday flyer" package. Whether learning yourself, or giving the gift of flight to someone who is new to RC Flying, the RotorScale EC135 delivers modern features that will stand the test of time.
    • Equipped with a 6-axis electronic gyroscope and barometer for precise stabilization and altitude measurement
    • 10-15 minutes of flight time
    • Impact resistant
    • Automatic stabilization system
    • Intelligent modular battery with one-touch LED display of charge level
    • Low voltage alarm
    • Out of control protection
    • RotorScale EC135 100 Size Gyro Stabilized Helicopter - RTF
    • 2.4GHz Radio Transmitter
    • 2S 330mAH 7.4V LiPo Battery
    • USB Charger
    • Spare Main Blade Set
    • Spare Tail Blade Set
    • Tools
    • Manual
    AGE LEVEL: 14 and up
    SKILL LEVEL: Beginner
    BUILD TIME: None
    Class / Size 100 Size
    Power Type Electric
    Rotor Type Fixed Pitch
    Body Material Plastic
    Overall Size (L x W x H) 235mm (9.3") x N/A x 81mm (3.2")
    Flying Weight 95g
    Main Rotor Diameter 256mm / 10.1"
    Main Rotor Blade Length N/A
    Tail Rotor Diameter N/A
    Tail Rotor Blade Length N/A
    Tail Drive Type 0720 Coreless Motor
    Cyclic Servos N/A
    Tail Servo N/A
    Power System 1023 Coreless Motor
    Electronic Speed Control Integrated
    Recommended Battery 2S 7.4V 330mAH LiPo Conformal Case Battery (Included)
    Required Radio 2.4GHz Radio (Included)
    Skill Level Beginner
    Build Time None
    Recommended Environment Large Indoor or Outdoor Area
  • brett27295
    • Feb 2023
    I just received my model and charged the battery and was able to sync the radio and heli together. All the controls work except throttle. I can hit the one button flight and it will fire up and take off and the one button land brings it back down. But if I try to do anything throttle related, its dead. I have removed battteries and re-sync'd it several times and nothing. What am I doing wrong or is there a issue i'm not seeing?
    • Tedstrickland
      • Jun 2019
      Can this heli use any of the standard TX protocols, like the Spectrum DSM, DSM2, or Futaba S-FHSS. I really love flying these mini scale birds, like the XK's but if it uses one of my larger standardized TX, all the better.
