This innovative aircraft combines the sport capabilities of a 450 size helicopter with the rock-solid stability of a GPS-stabilized flight control system. Similar to high-end drones, this system links with GPS satellites in orbit to maintain positional awareness at all times. Sold as an RTF ("Ready To Fly") package, this Fly Wing 450AF includes almost everything you need to fly except batteries. All radio programming is completed at the factory for you and Motion RC carries a full range of spare parts at an affordable price.
Featuring a carbon fiber frame, dual brushless motors, a high precision flybarless flight controller, and Omni H1 GPS technology, and a long flight duration of 8-13 minutes on an economical 4S LiPo battery, the 450AF is the perfect helicopter for intermediate pilots looking for a casual trainer that can also push the envelope toward sportier flying.
NOTE: the one-click reverse feature is turned off by default, as it may damage the body. This can be turned on by linking with a PC.
Durable and Stable The CNC-finished metal main rotor assembly and linkage layout is configured like larger class helicopters, positioning servos in optimal positions for mechanical advantage. The frame is laser cut from high strength aviation grade carbon fiber that resists twisting, and the durable landing skids’ widened stance improves clearance and stability when operating from firm, clear, and clean surfaces. |
Reliable Radio Control Featuring a modern 2.4GHz 10 channel radio transmitter, the 450L V2 can be operated near other RC vehicles without risk of losing signal. Conveniently, all of the basic flight mixes and functions are pre-programmed at the factory for you. Like any GPS-equipped flight system, the helicopter requires a one-time, ~15 second GPS calibration process that calibrates itself for your specific geographic region to improve the GPS’ accuracy. For advanced pilots, the expansive user manual includes instructions to unlock additional programming features via the radio’s convenient touchscreen LCD display. |
- User friendly GPS-assisted flight modes including One-Touch Takeoff and Automatic Landing via included pre-programmed radio transmitter
- RTF ("Ready To Fly") convenience with simple computer calibration and one minute physical assembly
- Dual Brushless Direct Drive Motor design eliminates 90% of moving parts for less vibration, less setup, and longer lifespan
- GPS automatic stabilization and 3D manual modes
- One-touch return to home
- Low power and signal loss automatic return to home
- Hands-free figure 8s
- Fly Wing 450AF Airwolf 450 Size GPS Stabilized Helicopter - RTF
- 2.4GHz radio and receiver
- Charger
- Flight battery
- Four (4) AA size batteries for the radio transmitter we recommend Admiral NiMH AA Rechargeable Batteries (4 Pack)
- Windows PC required for initial setup and calibration
AGE LEVEL : 14 and up
SKILL LEVEL : Intermediate
BUILD TIME : 10 Minutes
| Class / Size | 450 Size |
| Power Type | Electric |
| Rotor Type | Collective Pitch |
| Body Material | Plastic |
| Overall Size (L x W x H) | 860mm (33.9") x N/A x 190mm (7.5") |
| Flying Weight | 1,300g |
| Main Rotor Diameter | 805mm / 31.7" |
| Main Rotor Blade Length | 360mm / 14.2" |
| Tail Rotor Diameter | 125mm / 4.9" |
| Tail Rotor Blade Length | N/A |
| Tail Drive Type | 2008 Brushless Motor |
| Cyclic Servos | H041 Servo - RSH1005-112 |
| Tail Servo | N/A |
| Power System | 2816 Brushless Motor |
| Electronic Speed Control | 60A |
| Recommended Battery | Admiral 4S 2200mAh with XT60 connector |
| Battery Compartment Size (L x W x H) | N/A |
| Required Radio | 2.4GHz Radio (Included) |
| Skill Level | Intermediate |
| Build Time | 10 minutes |
