No throttle on F03
  • Skyjacker
    • Jun 2023
    • 3
    No throttle on F03
    I have a RotorScale F03 that I have been flying until about 10 days ago. Today I was going to fly, and I turned on the tx and the connected the battery to the helicopter. The binding took place, but I don't have the throttle control (left stick). The right stick appears to be okay. Any help would be appreciated..
    Skyjacker
  • Robert Popper
    • Jun 2023
    I would first suspect the batteries. The motor draws a lot of current and could not work when everything else does. If batteries OK, check the left/right movement of that stick. If the left/right stick movement works, , I would suspect a bad connection between the motor and ckt. board or a bad motor. If left/right stick function doesn't work either, would suspect bad joy stick , bad connection or bad ckt board.
    • Skyjacker
      • Jun 2023
      • 3
      • Skyjacker
        • Jun 2023
        • 3
        Thanks Robert. Based on your reply I think it's a bad motor
