Roban MD500 5 Blade Phasing
  • Apache 563
    • Jan 2021
    • 3
    Hello friends - thanks for reading, and maybe sharing some advice to me.. I am trying to determine how to insure my Roban MD500 Sheriff 5 bladed 800 size Heli rotor head is phased properly. I am using a Microbeast and DX9. I've not found much in the microbes to program for a 5 bladed head. I've ready here and there I must align one blade with the tail boom, then move cyclic fore and aft and the blade should not move, while the others will. at the moment this is how it is set up. Is this correct? Again, thank you..
  • DCORSAIR
    • 1918
    • Selma, Ca.
    If it's the stock 5 blade Roban head, it's already phased using the J arms that it has installed to the blade grips. I just hooked everything up as per the Microbeast instr. and flew mine, had 4 Roban helis with the Roban 4&5 blade heads with the Microbeast and they didn't require any programming in the Microbeast as for the blade count.
