Official RotorScale EC-135 180 Size Gyro Stabilized Helicopter Discussion Thread
  • jbaartz
    • Sep 2020
    • 483
    Introducing the RotorScale EC-135 Flybarless RC Helicopter – an exemplary high-performance platform crafted to cater to both novice operators and seasoned enthusiasts. This model impeccably replicates the Eurocopter EC-135 at a 1:36 scale, featuring intricate details and captivating lights for an authentic appearance.
    With a flybarless design, brushless direct-drive motors, and stability enhancement system, the EC-135 offers precise, stable flight maneuvers and control. The helicopter's rotor design ensures robust power, efficiency, and extended flight time, complemented by a durable fiber infused nylon rotor blades.
    Propelled by a 2507-1280KV brushless motor and a specialized 1204-7000KV brushless tail motor, the helicopter boasts low noise, ample torque, and exceptional stability. The aircraft's 6-axis gyroscope guarantees stable, precise flight attitudes, ideal for beginners seeking reliable control.
    The EC-135 employs a high-precision vision (optical flow) positioning sensor for position-holding stability, supported by 2.4GHz communication for uninterrupted control. A CNC-machined rotor head swash plate enhances durability, while an injection molded body ensures detailed and resilient construction.
    Ready To Fly
    Everything is included in the box except for four AAA batteries. Simply charge the included flight battery with the included USB charger, insert your four AAA batteries into the included radio transmitter, then read the manual in preparation for your first flight.
    Flight Stabilization System
    The integrated gyro system stabilizes the EC-135 helicopter in six axes. This system arrives fully configured from the factory and requires zero setup by the pilot.
    Scale Details
    The EC-135 has a super scale body with features such as antennas, panel lines, rivets and exhaust details.
    Reliable Radio Control
    Featuring a modern 2.4GHz radio transmitter, the EC-135 can be operated near other RC vehicles without risk of losing signal. The transmitter also has an audible low-battery warning alert and the helicopter will auto-land if the alert is ignored.
    One-Touch Inverted Flight
    The EC-135 will automatically flip to the inverted position with the press of a button and forward/aft stick movement. Easily return the helicopter upright with the same button and stick movement sequence.
    Dual Brushless Motors
    The RotorScale EC-135 features a brushless direct drive main motor and a brushless tail motor. The brushless motors are more efficient and responsive, giving you better control of the aircraft at all times.
    • Package includes everything needed to fly, minus 4 AAA transmitter batteries
    • Optical flow sensor allows for great position-hold capability, even in windier conditions
    • 6-axis gyro stabilized for relaxed, easy flying
    • Super scale body, including panel lines, antennas, rivet and exhaust details
    • One-Touch Landing allows for easy auto-landings
    • Intelligent battery shows the charge level with 4 LED lights
    • Audible low-battery warning signal on the transmitter
    • Automatic landing if the low battery warning signal on the transmitter is ignored
    • Direct drive, brushless main and tail motors
    • Scale 4-blade rotor head
    • One-Touch Inverted Flight automatically flips the helicopter to an inveted position
    • RotorScale EC-135 180 Size Gyro Stabilized Helicopter - RTF
    • 2.4GHz ransmitter
    • Flight battery
    • USB charging cable
    • Spare set of main blades and tail blade
    • Tools
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 10 Minutes
    Class / Size 180 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 350mm (13.8") X 85mm (3.3") X 120mm (4.7")
    Flying Weight 228g (8.0 oz)
    Main Rotor Diameter 330mm / 13"
    Main Rotor Blade Length 140mm (5.5 in.)
    Tail Rotor Diameter 75mm / 2.9"
    Tail Rotor Blade Length N/A
    Tail Drive Type 1204 brushless motor
    Cyclic Servos 4.3g digital servo
    Tail Servo N/A
    Power System 2508 burshless motor
    Electronic Speed Control 3-in-1 ESC 5V 3A
    Recommended Battery RotorScale 2S 14000mAh 25C LiPo battery
    Required Radio 2.4GHz radio (included)
    Skill Level Intermediate
    Build Time Less than 10 minutes
  • FrankB
    • Jul 2024
    I flew my new EC135. Flew great. I landed and pulled the sticks down and in. Now the motor will not start. Any ideas?
    • Robbo357
      • Feb 2024
      • 4
      Sadly, I have wrecked my EC-135. The following items are available as spares: battery, skids, spare rotor pack. Contact me via this page initially.
      • Jim Jacobs
        • Jul 2024
        • 23
        I’d be interested, pictures of what you have would be nice and how much
        • Robbo357
          • Feb 2024
          • 4
          Hi Jim,
          Thanks for your interest. With apologies, I have been able to resource another model of the same type, same manufacturer but different livery so the spares are no longer available...although, hopefully, I wont need the body parts.
          Best regards,
          Robbo357
          • Jim Jacobs
            • Jul 2024
            • 23
            Okay thanks .
