Official RotorScale UH-60 Black Hawk 220 Size GPS Stabilized Helicopter Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    The RotorScale UH-60 Black Hawk 220 Size GPS Stabilized Helicopter is an exceptional radio-controlled helicopter perfect for enthusiasts seeking an incredible flying experience. The UH-60's flight stabilization system incorporates a GPS, a pressure sensor, and an optical sensor, allowing for position hold even in windy conditions. With convenient one-button return home and auto landing capabilities, this helicopter ensures hassle-free flight operations. The intelligent battery included with the helicopter features four status LEDs, providing real-time information about the battery's charge level. The UH-60's high level of scale detail, including LED lights and sliding side doors, add to its aesthetic appeal. The shock-absorbing landing gear helps in smooth landings and add scale detail, while the direct drive main motor ensures efficiency and reduced noise.
    Safety is a priority with functions like one-key return, low-power intelligent return, loss of signal return, one-key landing, "heart-shaped" flight, and circular flight. The helicopter comes with a new 8-channel high precision remote control with a 2.4GHz two-way communication protocol and an LCD display. The transmitter supports digital parameter adjustments, and optimized joystick outputs for precise operation. The helicopter offers high efficiency, power-saving capabilities, and a long flight times. Its nylon composite material blades provide durability, strength, and impact resistance.
    Ready To Fly
    Everything is included in the box except for four AA batteries. Simply charge the included flight battery with the included USB charger, insert your four AA batteries into the included radio transmitter, then read the manual in preparation for your first flight.
    Flight Stabilization System
    The integrated gyro system stabilizes the UH-60 helicopter in six axes. This system arrives fully configured from the factory and requires zero setup by the pilot, and enables special features like "One Touch Landing".
    Scale Details
    The UH-60 offers scale features such as the lighting, sliding doors, and shock absorbing landing gear.
    Reliable Radio Control
    Featuring a modern 2.4GHz radio transmitter with and LCD display, the UH-60 can be operated near other RC vehicles without risk of losing signal.
    Return To Home Feature
    With the Return To Home feature, the UH-60 will always make a safe journey home in the event of a low battery or signal loss for that extra bit of confidence and insurance.
    Dual Brushless Motors
    The RotorScale UH-60 features a brushless direct drive main motor and a brushless tail motor. The brushless motors are more efficient and responsive, giving you better control of the aircraft at all times.
    • Package includes everything needed to fly, minus the four AA transmitter batteries
    • Flight stabilization system includes GPS, a pressure sensor, and an optical sensor
    • Intelligent battery with LED status lights
    • Shock absorbing landing gear
    • Direct drive main motor
    • A high level of scale details
    • RotorScale UH-60 Black Hawk 220 Size GPS Stabilized Helicopter - RTF
    • 2.4GHz transmitter
    • 3S Charger
    • 3S 11.1V 1350mAh LiPo Battery
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : None
    Class / Size 220 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 420mm (16.5") X N/A X 120mm (4.7")
    Weight (without battery) 435g (15.3 oz)
    Main Rotor Diameter 425mm / 16.7"
    Main Rotor Blade Length 213mm (8.4 in.)
    Tail Rotor Diameter 70mm / 2.75"
    Tail Rotor Blade Length N/A
    Tail Drive Type 1104 brushless motor
    Cyclic Servos 4.3g digital metal gear servos
    Tail Servo N/A
    Power System 4006 brushless motor
    Electronic Speed Control N/A
    Recommended Battery 3S 1350mAh LiPo battery
    Required Radio 2.4GHz Radio (Included)
    Skill Level Intermediate
    Build Time None
