RotorScale 450 MD500e PNP
  • flycatch
    • Dec 2018
    • 6
    Just received this item.I need to know how to remove and reinstall the internal mechanics. The helicopter does not come with an instruction manual. Upon inspection it appears you remove to screws and slide the mechanics out. This will work if the tail rotor assembly is driven by a torque tube not belt driven as this is.
  • ridgerunner
    • Nov 2017
    • 275
    • Central Utah, USA
    To remove the heli mechanics, first disassemble the tail. You need to remove the tail shaft. Then remove the four bolts on the bottom and the whole thing slides out the front. Reverse the process to re-assemble. I do recommend a full disassembly to ensure all parts requiring threadlock are threadlocked. (One of my Rotorscales had a loose pinion gear as well as several other loose bolts.)
