Official RotorScale 150 Size Bell 206 Gyro Stabilized Helicopter RTF Thread
    • 8211
    Experience the thrill of flight with the RotorScale Bell 206 150 Size Gyro Stabilized Helicopter, a meticulously crafted model that captures the essence of real-life rescue missions. This ready-to-fly helicopter includes everything you need to take to the skies—just add 4 AA batteries!
    Designed with beginners in mind, the Bell 206 features advanced 6-axis gyro stabilization for smooth and stable flights, allowing you to get in the air with confidence. The integrated optical flow sensor and altitude hold technology ensure precise position and altitude control, making it easy to hover steadily in the air. With its convenient one-click takeoff and landing feature, you can takeoff and land effortlessly, even if you’re new to flying.
    The stunning LA Fire livery not only adds a touch of realism but also makes this helicopter a standout piece in your collection. Whether you’re a novice or an experienced pilot, the reliable 2.4GHz control system provides long-range, interference-free connectivity for an uninterrupted flying experience.
    Elevate your flying adventures with the RotorScale Bell 206 150 Size Gyro Stabilized Helicopter—where cutting-edge technology meets authentic scale design!
    Visit the Official RotorScale Bell 206 150 Size Gyro Stabilized Helicopter Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
    Fly Out of the Box!
    The RotorScale Bell 206 arrives fully assembled and ready to take to the skies. No setup hassle—just charge the battery, and you're ready to fly!
    Precision Control with 6-Axis Gyro Stability
    Enjoy smooth flights and exceptional stability with the built-in 6-axis gyro, making it easy for beginners to stay in control.
    Steady Hovering with Optical Flow and Altitude Hold
    The advanced optical flow sensor, combined with altitude hold, ensures precise position control and stable hovering, making flights smoother and more beginner-friendly.
    Iconic LA Fire Rescue Livery
    Stand out with the stunning LA Fire livery, capturing the authentic style of emergency rescue helicopters for an eye-catching, scale appearance.
    Effortless Takeoff and Landing
    Perfect for beginners, the one-click takeoff and landing feature ensures smooth takeoffs and safe returns with the single press of a button.
    Uninterrupted Flying with Reliable 2.4GHz Technology
    Enjoy glitch-free control with 2.4GHz transmission, for an uninterrupted and confidence-inspiring flying experience.
    • Includes everything you need to start flying right away, just add 4 AA batteries
    • 6 axis gyro stabilization ensures smooth and stable flights for beginners and pros alike
    • Optical flow sensor helps maintain position, even in wind
    • Altitude hold feature assists in maintaining a steady altitude for less workload on the pilot
    • Takeoff and land effortlessly, with a single button press on the transmitter
    • Intelligent battery provides a quick reference battery level indicator
    • Automatic landing if the helicopter’s battery gets too low
    • Realistic fire livery inspired by LA rescue helicopters
    • Reliable 2.4GHz control provides solid, interference free connectivity
    • RotorScale Bell 206 150 Size Gyro Stabilized Helicopter - RTF
    • 2.4 GHz Transmitter
    • Flight Battery
    • USB Charger
    • Spare set of main blades and tail rotor
    • Screwdriver and Hex Wrench
    • Instruction Manual
    Requires:
    Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :beginner
    BUILD TIME :less than 10 minutes
    Scale 1/40
    Class / Size 150 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 312mm (12.3 in) x 70mm (2.75 in) x 101mm (4.0 in)
    Weight (without battery) 105g (3.7oz)
    Main Rotor Diameter 306mm / 12"
    Main Rotor Blade Length 138mm / 5.4"
    Tail Rotor Diameter 52mm / 2"
    Tail Rotor Blade Length N/A
    Tail Drive Type Coreless Brushed Motor
    Cyclic Servos 3x 2g Servos
    Tail Servo N/A
    Power System Coreless Brushed Motor
    Electronic Speed Control 3-in-1 ESC
    Recommended Battery RotorScale 2S 350mAh Battery
    Required Radio 2.4GHz Radio (Included)
    Skill Level Beginner
    Build Time Less than 10 minutes
  • Jim Jacobs
    • Jul 2024
    • 23
    Definitely is a fun helicopter
    • mpence
      • Sep 2021
      • 3
      Can this heli be bound to a TX16S radio?
