Official RotorScale 200 Size UH-1 Huey Gyro Stabilized Helicopter RTF Thread
    • 8231
    UH-1 Huey 200 Size Gyro Stabilized Helicopter - RTF from RotorScale - RSH1020-001
    Take to the skies with the RotorScale UH-1D Huey 200 Size Gyro Stabilized Helicopter! This fully assembled, ready-to-fly model brings the iconic Vietnam-era Huey to life with realistic scale details and a classic military livery. Designed for both stability and precision, it features an advanced 6-axis gyro and multiple onboard sensors for superior position and altitude hold.
    Powered by dual brushless motors and an intelligent 7.4V LiPo battery, the UH-1D delivers smooth, reliable flights with up to 10 minutes of airtime. Whether you're a beginner or a seasoned pilot, this legendary workhorse is built to provide an exciting, immersive flight experience from takeoff to touchdown.
    Fly Right Out of the Box!
    The RotorScale UH-1D arrives fully assembled and flight ready. No hassle—just charge the battery, and you're ready to fly!
    Precision Control with 6-axis Gyro Stabilization
    Experience smooth, stable flights with the built-in 6-axis gyro, ensuring precise control and effortless handling.
    Rock Solid Hovering with Optical Flow and Altitude Hold
    An advanced optical flow sensor and barometric altitude hold sensor work together in harmony to deliver exceptional stability keeping your helicopter locked in position.
    High Quality, Detailed Fuselage
    Enjoy an authentic, scale, Vietnam-era experience with a highly detailed fuselage featuring simulated exhaust, vent openings and realistic rivet details.
    Fly Virtually Anywhere with a Convenient Size
    The perfect size for versatile flying. Take your RotorScale helicopter with you and fly just about anywhere with ease!
    Reliable 2.4 GHz Technology for Uninterrupted Control
    Fly with confidence using a dependable 2.4GHz radio system, ensuring a strong, interference-free link between you and the helicopter.
    • Completely ready-to-fly package includes everything needed to start flying, requiring only 4 AA batteries for the transmitter
    • Enhanced stability and control with a 6-axis gyro for smoother, stable flights
    • Optical flow positioning maintains position and ensures stable hovering
    • Barometric pressure sensor helps maintain altitude and provides steady altitude control
    • Highly detailed scale fuselage delivers an authentic and realistic appearance of the Vietnam-era UH-1D Huey
    • LED lighting enhances the scale appearance for a more realistic scale flying experience
    • Efficient and powerful brushless main and tail motors provide strong, reliable performance
    • Intelligent 7.4V 1200mAh battery features built-in status indicator for monitoring charge levels, and conveniently charges with a USB-C cable
    • Carbon fiber-reinforced nylon main blades enhance durability and efficiency
    • One-button inverted flight function enables effortless aerobatics
    • High-torque servos offer fast response and precise control
    • Reliable 2.4GHz control system ensures solid, interference-free connectivity
    • Up to 10 minutes of flight time with the included battery
    • RotorScale UH-1 Huey 200 Size Gyro Stabilized Helicopter - RTF
    • 2.4 GHz Transmitter
    • 1x Intelligent Flight Battery
    • Battery Charger
    • Screwdriver Set
    • Instruction Manual
    AGE LEVEL :14 and up
    SKILL LEVEL :Beginner
    BUILD TIME :None
    Class / Size 200 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 385mm (15.2 in) x x 120mm (4.7 in) x 110mm (4.3in)
    Weight (with battery) 296g (10.4oz)
    Main Rotor Diameter 375mm / 14.8"
    Main Rotor Blade Length 164mm / 6.5"
    Tail Rotor Diameter 73mm / 2.9"
    Tail Rotor Blade Length N/A
    Tail Drive Type 1204 5300Kv Brushless Outrunner Motor
    Cyclic Servos 3x 4.3g Digital Servos
    Tail Servo N/A
    Power System 2511 1200Kv Brushless Motor
    Electronic Speed Control 30A 2-in-1 ESC
    Recommended Battery 2S 1200mAh LiPo
    Required Radio 2.4GHz Radio (Included)
    Skill Level Beginner
    Build Time Less than 10 minutes
  • Coconut
    • Apr 2019
    • 212
    When is it coming back in stock?
    • Jimbo82abn
      Jimbo82abn
      • Jun 2025
      • 11
      • South Carolina
      What is the cost?
      • Dajoux
        • Jun 2025
        Bonjour, a quand les helico rtf grande taille, 600 merci
        • GeoMiWill
          • Jul 2025
          How to troubleshoot what appears to be lost connection to helicopter. After a couple flights. The helicopter kept veering off in one direction. And climbing. Not sure if we have a setting on the controller that is not correct. The controller was also beeping at the same time
