Official RotorScale 200 Size Bell 206 Gyro Stabilized Helicopter RTF Thread
  • Official RotorScale 200 Size Bell 206 Gyro Stabilized Helicopter RTF Thread
    Bell 206 200 Size Gyro Stabilized Helicopter - RTF from RotorScale - RSH1021-001
    Get ready for an unforgettable flight experience with the RotorScale Bell 206 200 Size Gyro Stabilized Helicopter! This fully assembled, ready-to-fly model combines exceptional stability and precision control with its advanced 6-axis gyro and multiple onboard sensors for precise position and altitude hold. Featuring a sleek livery and realistic scale details, the Bell 206 stands out in both performance and appearance.
    Powered by two brushless motors, and an intelligent 7.4V LiPo battery, it provides smooth, reliable flights with up to 10 minutes of airtime. Whether you're just starting or already an experienced pilot, the RotorScale Bell 206 is built for excitement from the moment you take off to the moment you land.
    Fly Right Out of the Box!
    The RotorScale Bell 206 arrives fully assembled and flight ready. No hassle—just charge the battery, and you're ready to fly!
    Precision Control with 6-axis Gyro Stabilization
    Experience smooth, stable flights with the built-in 6-axis gyro, ensuring precise control and effortless handling.
    Rock Solid Hovering with Optical Flow and Altitude Hold
    An advanced optical flow sensor and barometric altitude hold sensor work together in harmony to deliver exceptional stability keeping your helicopter locked in position.
    High Quality, Detailed Fuselage
    Enjoy an authentic scale experience with a highly detailed fuselage featuring simulated exhaust, vent openings and realistic rivet details.
    Fly Virtually Anywhere with a Convenient Size
    The perfect size for versatile flying. Take your RotorScale helicopter with you and fly just about anywhere with ease!
    Reliable 2.4 GHz Technology for Uninterrupted Control
    Fly with confidence using a dependable 2.4GHz radio system, ensuring a strong, interference-free link between you and the helicopter.
    • Completely ready-to-fly package includes everything needed to start flying, requiring only 4 AA batteries for the transmitter
    • Enhanced stability and control with a 6-axis gyro for smoother, stable flights
    • Optical flow positioning maintains position and ensures stable hovering
    • Barometric pressure sensor helps maintain altitude and provides steady altitude control
    • Highly detailed scale fuselage delivers an authentic and realistic appearance
    • LED lighting enhances the scale appearance for a more realistic scale flying experience
    • Efficient and powerful brushless main and tail motors provide strong, reliable performance
    • Intelligent 7.4V 1200mAh battery features built-in status indicator for monitoring charge levels, and conveniently charges with a USB-C cable
    • Carbon fiber-reinforced nylon main blades enhance durability and efficiency
    • One-button inverted flight function enables effortless aerobatics
    • High-torque servos offer fast response and precise control
    • Reliable 2.4GHz control system ensures solid, interference-free connectivity
    • Up to 10 minutes of flight time with the included battery
    • RotorScale Bell 206 200 Size Gyro Stabilized Helicopter - RTF
    • 2.4 GHz Transmitter
    • 1x Intelligent Flight Battery
    • Battery Charger
    • Screwdriver Set
    • Instruction Manual
    AGE LEVEL :14 and up
    SKILL LEVEL :Beginner
    BUILD TIME :None
    Class / Size 200 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 390mm (15.4 in) x 122mm (4.8in) x 75mm (3.0 in)
    Weight (with battery) 292g (10.3oz)
    Main Rotor Diameter 375mm / 14.8"
    Main Rotor Blade Length 164mm / 6.5"
    Tail Rotor Diameter 73mm / 2.9"
    Tail Rotor Blade Length N/A
    Tail Drive Type 1204 5300Kv Brushless Outrunner Motor
    Cyclic Servos 3x 4.3g Digital Servos
    Tail Servo N/A
    Power System 2511 1200Kv Brushless Motor
    Electronic Speed Control 30A 2-in-1 ESC
    Recommended Battery 2S 1200mAh LiPo
    Required Radio 2.4GHz Radio (Included)
    Skill Level Beginner
    Build Time Less than 10 minutes
