Official RotorScale 200 Size Airwolf GPS Stabilized Helicopter RTF Thread
    • 8228
    Airwolf 200 Size GPS Stabilized Helicopter - RTF from RotorScale - RSH1022-001
    Inspired by the iconic TV series Airwolf, this 200-size scale helicopter combines stunning detail with modern flight stabilization technology for an unmatched flying experience. The RotorScale Airwolf is equipped with GPS positioning, barometric altitude hold, and laser radar and optical flow sensors, delivering smooth and precise control whether you’re a seasoned pilot or a first-time flyer.
    With a CNC-machined rotor head, carbon-infused rotor blades, and a high-efficiency flybarless system, performance meets realism in one ready-to-fly package. Scale lighting and detailed armament replicas complete the look, while the included 8-channel transmitter with HD display gives you live telemetry feedback for total situational awareness.
    Whether you're hovering in place or engaging one-button flight modes like inverted flight or figure 8 patterns, the RotorScale Airwolf brings fun TV-inspired action to the skies—no setup required.
    Legendary Design, Modern Performance
    Faithfully modeled after the iconic TV helicopter, the Airwolf delivers scale looks backed by state-of-the-art stabilization and control.
    Fly Right Out of the Box!
    The RotorScale Airwolf arrives fully assembled and flight ready. No hassle—just charge the battery, and you’re ready to take off.
    Scale Lighting for Realism and Orientation
    Integrated navigation lighting adds an authentic touch and improves visibility during low-light flights.
    Carry It in Style
    The included aluminum case keeps your helicopter and accessories protected—at home or at the field.
    One-Button Flight Patterns
    Execute dramatic inverted flight and smooth figure-eight maneuvers with the press of a button—perfect for impressing your flying buddies.
    Reliable 2.4 GHz Technology for Uninterrupted Control
    Fly with confidence using a dependable 2.4GHz radio system, ensuring a strong, interference-free link between you and the helicopter.
    Real-Time Telemetry at Your Fingertips
    The included transmitter features a color display with real-time feedback on battery voltage, altitude, flight speed, and more.
    Detailed from Gear to Rotor
    A CNC-machined rotor head, carbon-infused blades, and highly detailed fuselage make this helicopter as refined as it is rugged.
    • GPS stabilized flight provides rock-solid positioning and effortless hover stability
    • Advanced sensor suite combines laser radar, optical flow, and barometric sensors that seamlessly work together to enhance stability, altitude hold and ground reference – even in less than ideal conditions
    • Highly detailed Airwolf fuselage replicates the iconic TV helicopter with accurate contours and integrated scale armament details
    • Scale lighting system adds visual realism and enhances orientation during low-light flying
    • Aluminum carrying case securely houses the helicopter and all accessories for easy transport and storage
    • CNC machined rotor head ensures smooth, responsive cyclic control with long-lasting durability
    • Flybarless rotor system improves efficiency and responsiveness while reducing mechanical complexity
    • One-button inverted flight mode enables automatic inverted flight for beginner-friendly aerobatics
    • One-button figure 8 mode performs smooth, pre-programmed figure-eight flight patterns with minimal input
    • 8-Channel 2.4GHz transmitter with HD display provides two-way telemetry feedback, including battery level, flight speed, altitude, distance, orientation and GPS signal count
    • Carbon fiber infused rotor blades deliver high efficiency, strength and precise handling
    • RotorScale Airwolf 200 Size GPS Stabilized Helicopter - RTF
    • Aluminum Carrying Case
    • 8-Channel, 2.4 GHz Transmitter with Color Display
    • 1x Intelligent Flight Battery
    • Spare Main Rotor Blades (1 set of 2 blades)
    • Spare tail rotor (1)
    • Hex Key
    • Screwdriver
    • USB Charging Cable
    • Instruction Manual
    AGE LEVEL :14 and up
    SKILL LEVEL :Beginner
    BUILD TIME :None
    Class / Size 200 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 415mm (16.3 in) x 136mm (5.3 in) x 118mm (4.6 in)
    Weight (with battery) 310g (10.9oz)
    Main Rotor Diameter 375mm / 14.8"
    Main Rotor Blade Length 164mm / 6.5"
    Tail Rotor Diameter 70mm / 2.75"
    Tail Rotor Blade Length N/A
    Tail Drive Type 1204 5300Kv Brushless Outrunner Motor
    Cyclic Servos 3x 4.3g Digital Servos
    Tail Servo N/A
    Power System 2511 1200Kv Brushless Motor
    Electronic Speed Control 30A 2-in-1 ESC
    Recommended Battery 2S 1200mAh LiPo
    Required Radio 2.4GHz Radio (Included)
    Skill Level Beginner
    Build Time Less than 10 minutes
