Official Roban 800 Size AS365 Australian Life Saver Scale Helicopter ARF Thread
    • 8231
    AS365 Australian Life Saver 800 Size Scale Helicopter ARF (Almost Ready to Fly) from Roban - RBN-AS365LS8
    The Roban 800-Size AS365 Dauphin is a breathtaking large-scale RC helicopter built for pilots who demand true presence, uncompromising realism, and the freedom to build their helicopter their way. From its massive airframe to the unmistakable Fenestron tail and multi-blade rotor system, this model captures the character and authority of the full-scale AS365 like few RC helicopters ever have.
    Finished in the high-visibility Australian Life Saver livery, this AS365 captures the unmistakable look of coastal rescue helicopters operating in demanding maritime environments. Designed as an ARF for experienced builders, it allows you to select and install your preferred electronics while delivering factory-installed scale features that elevate the finished model to show-quality status. A fully illuminated cockpit, retractable landing gear, functioning doors, and integrated LED lighting bring the aircraft to life on the ground and in the air. Build a flagship-level scale helicopter in this authentic livery—an unmistakable presence that demands attention every time it spools up.
    Show-Quality Scale Fuselage
    The AS365 features an exceptionally detailed fiberglass fuselage with crisp panel lines, molded scale features, and accurate proportions throughout. Functioning scale doors add another layer of realism and enhance both display and scale presentation.
    Fully Functional Fenestron Tail
    A true 9-blade Fenestron tail is fully functional, delivering authentic anti-torque performance while perfectly replicating the Dauphin’s iconic tail design. This signature feature completes the aircraft’s unmistakable scale profile.
    Illuminated Scale Cockpit Included
    A fully detailed scale cockpit is included, complete with integrated lighting, scale seats, and control stick details. The illuminated interior adds depth, realism, and show-quality presence.
    Premium Carbon Fiber Rotor Blades
    The included 4-blade carbon fiber rotor blades are factory painted and precisely balanced for smooth, confident operation. Designed specifically for this scale rotor system, they enhance both realism and flight quality.
    • Massive 800-size scale airframe delivers commanding presence and unmistakable realism
    • Exceptionally detailed scale fuselage with crisp panel lines, molded surface features, and functioning doors
    • Authentic 4-blade rotor system with painted and factory-balanced carbon fiber blades included
    • Fully functional 9-blade Fenestron tail for true AS365 scale appearance and anti-torque performance
    • Fully illuminated scale cockpit included, featuring detailed seating and control stick elements
    • Integrated scale LED lighting system enhances realism during ground operations and flight
    • Electronic retractable landing gear included for true-to-life takeoff, landing, and in-flight profile
    • Full CCPM-style mechanics maintain proper geometry while preserving cockpit space
    • Designed as a premium ARF RC helicopter, allowing builders full freedom to select their preferred electronics
    • Ideal foundation for high-end scale builds, display flying, and event-level presentation
    • Roban AS365 800 Size Scale Fuselage
    • Full 800 Size helicopter mechanics
    • 4 x Balanced, Carbon Fiber Rotor Blades
    • Fenestron Tail
    • Illuminated scale cockpit
    • Lighting System
    • Retractable landing gear
    Roban Scale Helicopters are intended for modelers who have advanced level building skills. Both ARF and KIT product formats require you to install your own electronics (ESC, servos, motor, etc). KIT product formats also require you to install your own helicopter mechanics. Because helicopter mechanics can vary greatly in size and shape, you may be required to modify the fuselage slightly (including cutting, drilling, etc.) to achieve a perfect fit. Roban fuselages are all handmade from fiberglass and therefore may have slight variation in tolerances between body panels, doors, or windows. These variations do not affect flight performance and can be easily adjusted by an experienced builder with proper tools. These precautions are intended for novice builders; an experienced modeler should have no issue achieving perfect results with these premiere scale helicopters kits. Product Specifications:
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Expert
    BUILD TIME : 4+ Hours
    Class / Size 800
    Scale 1/8
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 1760mm (69.3 in) x 360mm (14.2 in) x 500mm (19.7 in)
    Flying Weight 4.5kg (32lb) with battery
    Main Rotor Diameter 1660mm (65.3 inches)
    Main Rotor Blade Length 750mm (29.5 inches)
    Tail Rotor Diameter 160mm (6.3in)
    Tail Rotor Blade Length 70mm (2.8in)
    Tail Drive Type Torque Tube
    Cyclic Servos Required 3x 70 oz/in (5kg/cm) torque or greater, Digital, Metal Gear servos – MKS 1220 High Torque Recommended
    Tail Servo Required 1x 115 oz/in (8kg/cm) torque or greater, digital, metal gear servo - MKS HBL550 X5 Recommended
    Power System Required 4230 435Kv Brushless Motor, EGODRIFT 4230EC Eclipse 4230-465Kv Brushless Motor Recommended
    Electronic Speed Control Required 160A, High Voltage ESC, Castle Creations Phoenix Edge High Voltage 160A ESC Recommended
    Recommended Battery 2x 6S 5000mAh 35C or Greater LiPo - Admiral 6S 5000mAh LiPo Battery with EC-5 Connector Recommended
    Required Radio 8 Channel Transmitter with throttle and pitch curves
    Skill Level Expert
    Build Time 4+ Hours
