Official RotorScale BO-105 Super Scale 450 Size GPS Stabilized Helicopter Thread
  • Official RotorScale BO-105 Super Scale 450 Size GPS Stabilized Helicopter Thread
    Link to purchase:
    Fly a true helicopter icon with the RotorScale BO-105 Super Scale 450 Size GPS-Stabilized Helicopter. With its unmistakable profile, external stores, and...
    BO-105 Super Scale 450 Size GPS Stabilized Helicopter - RTF from RotorScale - RSM-450-R-BO-PH223
    Fly a true helicopter icon with the RotorScale BO-105 Super Scale 450 Size GPS-Stabilized Helicopter. With its unmistakable profile, external stores, and authentic Philippine Army livery, the BO-105 delivers a bold, purpose-driven presence that stands apart in the air.
    Built around RotorScale’s proven GPS-stabilized flight system and a 450 size mechanical layout, the BO-105 pairs confident control with an exceptional level of scale fidelity. A highly detailed fiberglass fuselage, crisp panel lines, molded surface features, and realistic scale lighting give the aircraft a true-to-life appearance that holds up both in the air and up close. External stores, accurate proportions, and the scale four-blade rotor system further reinforce the BO-105’s distinctive utility helicopter character from every angle.
    Advanced GPS stabilization actively holds both altitude and position, allowing pilots to enjoy stable, realistic utility helicopter flight with confidence and ease. Features such as Return to Home provide added reassurance during flight, freeing pilots to focus on smooth maneuvers, scale passes, and enjoying the unique character of this helicopter.
    Arriving completely Ready to Fly, the BO-105 includes everything needed to get airborne, making it an ideal choice for pilots who want a distinctive, high-presence scale helicopter experience backed by steady, GPS-assisted control.
    Ready When You Are
    Factory setup means minimal prep. Install the main blades, charge the battery, add 4 AA transmitter batteries, and enjoy your first flight.
    Advanced GPS Stabilization
    Advanced GPS stabilization actively holds both altitude and position, allowing pilots to experience realistic missions with confidence and ease.
    Scale Four Blade, Flybarless Rotor System
    The four blade, flybarless rotor head delivers smooth, stable flight characteristics while enhancing the BO-105’s realistic scale appearance.
    Scale Weapon Details
    Detailed external stores enhance the BO-105’s distinctive military appearance, adding visual impact and authentic utility helicopter character in the air.
    Professionally Finished and Highly Detailed Fiberglass Fuselage
    The professionally painted fiberglass fuselage features crisp panel lines, molded surface details, and an authentic Philippine Army livery for a true-to-life appearance.
    Realistic LED Lighting
    Integrated LED lighting enhances scale authenticity and improves visibility during early morning or late evening flights.
    • Completely Ready to Fly package includes everything needed to start flying right away, just add 4 AA transmitter batteries
    • Advanced GPS stabilization delivers rock solid, steady, beginner friendly flight performance
    • 450 size airframe provides excellent stability, efficiency, and realistic presence in the air
    • Scale weapon details enhance the BO-105’s distinctive utility and military appearance
    • High quality, professionally painted fiberglass fuselage molded with panel lines and detailed scale surface features
    • Realistic LED lighting system enhances authenticity and improves visibility during flight
    • Four blade rotor head delivers smooth flight characteristics and true scale realism
    • Three selectable flight modes adapt to pilot skill level, including GPS Mode, Angle Mode, and Manual traditional helicopter Mode
    • Return to Home and auto land function ensures safe, easy recovery, especially for newer pilots
    • Carbon fiber frame construction provides excellent rigidity while remaining lightweight
    • Brushless main and tail motors deliver high efficiency, smooth power, and long term reliability
    • Reliable 2.4GHz control system ensures solid, interference free connectivity
    • RotorScale BO-105 Super Scale 450 Size GPS Stabilized Helicopter – RTF
    • 2.4 GHz Transmitter
    • Flight Battery
    • Charger
    • Instruction Manual
    Requires:
    • Four (4) AA batteries for the transmitter
    Product Specifications:
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Intermediate
    BUILD TIME : Less than 10 minutes
    Class / Size 450 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Fiberglass
    Overall Size (L x W x H) 750mm (29.5 in) x 155mm (6.1 in) x 240mm (9.4 in)
    Flying Weight 1545g (3lb 6.5oz) with battery
    Main Rotor Diameter 745mm (29.3 inches)
    Main Rotor Blade Length 335mm (13.2 inches)
    Tail Rotor Diameter 130mm (5.1 inches)
    Tail Rotor Blade Length N/A
    Tail Drive Type 2500Kv Brushless Outrunner Motor
    Cyclic Servos 3x 12g, Digital, Metal Gear Servos
    Tail Servo N/A
    Power System 2820 1300Kv Brushless Motor
    Electronic Speed Control 60A, 2-in-1 ESC
    Recommended Battery 4S 3000-4500mAh LiPo Battery - EPR40004X6
    Required Radio 2.4GHz Radio (included)
    Skill Level Intermediate
    Build Time Less than 10 minutes
    Fedex just dropped mine off. Have it on the counter nose to nose with my Flywing Bo-105 Spanish Policia livery. Gotta say, like the Rotorscale/Roban fuselage much better, more detailed and a little more accurate. Also have always been a fan of obscure liveries, considering the Philippine Army just signed off on getting the 105's this is a perfect choice for what is hopefully a "first" release of this helo with more to come. Finally an OEM large scale armed 105, love it! Awesome bird, thanks Motion!
