Link to purchase:
AH-1W Cobra Super Scale 470 Size GPS Stabilized Helicopter - RTF from RotorScale - RSM-470-R-AH1-GR
Strike a commanding presence in the air with the RotorScale AH-1W Super Cobra 470 Size GPS-Stabilized Helicopter. Modeled after the iconic twin-engine attack helicopter, this scale replica captures the aggressive lines, narrow fuselage, and unmistakable silhouette that define the Cobra’s legendary role.
Built on RotorScale’s proven 470-size platform, the AH-1W Super Cobra blends high-detail scale modeling with advanced GPS-assisted flight control, delivering a helicopter that looks incredible in the air while remaining approachable for pilots newer to helicopters. The streamlined fuselage, tandem cockpit layout, and realistic rotating chin turret give the model a purpose-built, mission-ready appearance from every angle.
Advanced GPS stabilization delivers exceptional stability by actively holding both altitude and position, allowing the helicopter to hover confidently with virtually no input. Integrated features such as Return-to-Home and intelligent flight protection provide added confidence while learning. As pilot skills advance, Angle Mode and Manual Mode unlock progressively more direct control, providing a smooth transition into full helicopter flight characteristics.
Arriving completely Ready-to-Fly, this helicopter includes everything needed to get airborne, making it an ideal choice for pilots looking to step into high-detail military scale without the complexity of a custom build.
AGE LEVEL : 14 and Up
SKILL LEVEL : Intermediate
BUILD TIME : Less than 10 minutes
| Fly Out of the Box! The AH-1W Cobra arrives fully assembled and ready to take to the skies. There is no setup hassle. Simply charge the battery, install the main blades, add 4 AA transmitter batteries, and you are ready to fly. |
| Advanced GPS Stabilization Advanced GPS stabilization delivers rock solid, beginner friendly flight performance while also allowing pilots to progress into more advanced control. Available flight modes include GPS Mode, Angle Mode, and Manual Mode, accommodating a wide range of skill levels. |
| Authentic Gunship Animation The scale rotating chin turret responds in real time to control inputs, delivering an ultra-realistic Cobra gunship appearance during flight. |
| High Quality, Detailed Fiberglass Fuselage The exquisitely crafted fiberglass fuselage is molded with panel lines, rivet details, and exhaust features, delivering an exceptional level of scale realism from every angle. |
| Realistic LED Lights Integrated LED lighting enhances scale authenticity and improves visibility during early morning or late evening flying. |
| Large, 470 Size The large 470 size airframe, combined with an 840 mm diameter main rotor, provides impressive stability, power, and presence in the air. |
- Completely Ready to Fly package includes everything needed to start flying right away, just add 4 AA transmitter batteries
- Advanced GPS stabilization delivers rock solid, steady, beginner friendly flight performance
- Larger 470 size airframe offers enhanced stability, presence, and power for confident outdoor flying
- Scale, rotating chin turret responds in real time to control inputs, delivering an ultra-realistic Cobra gunship look in flight
- High quality, professionally painted fiberglass fuselage molded with panel lines, rivet detail, and exhaust features for maximum scale realism
- Realistic LED lighting system enhances authenticity and improves visibility
- Professionally painted dark gray main blades replicate the authentic military appearance of the full scale Cobra
- Three selectable flight modes adapt to pilot skill level, including GPS Mode, Angle Mode, and Manual Mode
- Return to Home and auto land function ensures safe, easy recovery, especially for newer pilots
- Carbon fiber frame construction provides excellent rigidity while remaining lightweight
- Brushless main and tail motors deliver high efficiency, strong performance, and long-term reliability
- Reliable 2.4GHz control system ensures solid, interference free connectivity
- RotorScale AH-1W Cobra Super Scale 470 Size GPS Stabilized Helicopter – RTF
- 2.4 GHz Transmitter
- Flight Battery
- Charger
- Instruction Manual
- Four (4) AA batteries for the transmitter
BUILD TIME : Less than 10 minutes | Class / Size | 470 Size |
| Power Type | Electric |
| Rotor Type | Collective Pitch |
| Body Material | Fiberglass |
| Overall Size (L x W x H) | 810mm (31.9 in) x 210mm (8.3 in) x 270mm (10.6 in) |
| Flying Weight | 1228g (2lb 11oz) without battery |
| Main Rotor Diameter | 840mm |
| Main Rotor Blade Length | 376mm |
| Tail Rotor Diameter | 127mm |
| Tail Rotor Blade Length | N/A |
| Tail Drive Type | 2205 2450Kv Brushless Motor |
| Cyclic Servos | 3x 12g, Digital, Metal Gear Servos |
| Tail Servo | N/A |
| Power System | 2820 1300Kv Brushless Motor |
| Electronic Speed Control | 60A, 2-in-1 ESC |
| Recommended Battery | 4S 4000-4800mAh LiPo Battery |
| Battery Compartment Size (L x W x H) | N/A |
| Required Radio | 2.4GHz Radio (included) |
| Skill Level | Intermediate |
| Build Time | Less than 10 minutes |
.png)
