Official Rotorscale 150 Size H-1 Huey “114th AHC” Gyro Stabilized Helicopter RTF Discussion Thread
    • 8231
    H-1 Huey “114th AHC” 150 Size Gyro Stabilized Helicopter - RTF from Rotorscale - RSH1024-001
    The RotorScale UH-1 Huey brings one of the most iconic helicopters of all time to your flight line in a compact 150 size ready-to-fly package. Painted in the historic 114th Assault Helicopter Company, 1st Aviation Brigade scheme, this model pays tribute to the Huey’s legendary role in Vietnam while delivering modern stabilization and control for today’s RC pilots.
    Equipped with 6-axis gyro stabilization and an optical flow positioning system, the Huey maintains rock-solid hovering performance and steady forward flight even in the hands of less experienced pilots. Takeoffs and landings are simplified with one-touch auto functions, while advanced pilots can explore inverted flight at the push of a button.
    With its factory-applied scale finish, beautifully molded panel line and rivet detail, and LED navigation lights, this Huey looks every bit as authentic as it flies. Best of all, it arrives completely ready-to-fly with transmitter, battery, charger, and accessories included—just add four AA batteries, and you’re ready for your first mission.
    Iconic Vietnam-Era Detail
    The UH-1 Huey defined an era, and this model brings that legacy to life in miniature. Molded panel lines, rivet detail, and a historic 114th AHC paint scheme recreate the unmistakable look of the Huey. Optional nose art decals add a personal touch of authenticity.
    Ready-to-Fly In Minutes
    No building, no setup headaches—everything you need is included. The transmitter, battery, charger, and helicopter come pre-configured, so you can go from box to flight line in minutes. Just charge the LiPo, install four AA batteries in the transmitter, and launch your first mission with total confidence.
    Scale 2-Blade Flybarless Rotor
    The Huey’s iconic two-blade rotor is recreated in this flybarless rotor head design that delivers smooth, precise handling while preserving the scale look of its full-size counterpart. Every hover and turn feels natural, creating both realism and control in one simple design.
    6-Axis Gyro with Optical Flow
    Flight stability is built right in thanks to advanced 6-axis gyro technology. The optical flow sensor actively scans the surface below, locking the helicopter into position with incredible accuracy. Together, these systems help eliminate drift, making hovering effortless for beginners and rock-solid for scale flyers.
    One-Touch Auto Takeoff and Landing
    Takeoffs and landings are no longer stressful! With the press of a button, the Huey lifts smoothly into a steady hover or touches down with precision. These auto functions handle the hardest parts of flying for you, so you can focus on learning control and enjoying the flight. Even first-time pilots can look like pros right out of the box.
    Inverted Flight at the Push of a Button
    The Huey doesn’t just fly scale, it brings the fun too. Engage one-key inverted mode and watch as the helicopter flips over and keeps flying upside down with full control. It’s a jaw-dropping feature that turns heads and delivers aerobatic excitement without the steep learning curve.
    • Completely ready-to-fly package includes everything needed to start flying -- simply charge the battery, insert 4x AA batteries into the transmitter and fly!
    • Finely detailed scale fuselage replicates the UH-1 Huey with beautifully molded panel lines and rivet detail
    • Factory-applied camouflage finish with optional nose art decal set allows for authentic scale realism
    • 6-axis gyro stabilization ensures smooth, stable flight in all conditions
    • Optical flow positioning system locks the helicopter in place when hovering
    • One-touch auto takeoff and landing functions simplify operation for new pilots
    • One-key inverted flight mode makes inverted flight possible at the press of a button
    • LED navigation lights improve visibility and enhance scale presence
    • Scale 2-blade flybarless main rotor blade system
    • Durable rotor head and tail rotor system ensures reliable performance
    • Factory-installed servos, main motor, and flight controller for quick setup
    • USB-C charging system for convenient charging from computer or power bank
    • Reliable 2.4GHz control system ensures strong, interference-free connectivity
    • Lightweight yet robust construction designed for everyday flying durability
    • Spare tools and accessories included to keep your Huey mission-ready
    • RotorScale UH-1 Huey 150 Size Helicopter - RTF
    • Factory-installed brushless motor, ESC, and stabilization system
    • 2.4GHz 6-channel transmitter
    • 2S LiPo flight battery
    • USB balance charger
    • Tools and accessories for maintenance
    • Detailed instruction manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : less than 10 minutes
    Scale 1/40
    Class / Size 150 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 297mm (11.7") X 110mm (4.3”) X 101mm (3.98")
    Weight (with battery) 115g (4.0 oz)
    Main Rotor Diameter 315mm / 12.4"
    Main Rotor Blade Length 140mm (5.51”)
    Tail Rotor Diameter 52mm / 2.0"
    Tail Rotor Blade Length N/A
    Tail Drive Type Factory-installed brushless motor
    Cyclic Servos 2g digital metal gear servos
    Tail Servo N/A (direct drive system)
    Power System Factory-installed direct drive brushless motor
    Electronic Speed Control Integrated brushless ESC
    Recommended Battery 2S 350mAh LiPo battery (included)
    Required Radio 2.4GHz Radio (Included)
    Skill Level Beginner
    Build Time Less than 10 minutes
    Recommended Environment Indoors/Outdoors
