Official RotorScale 250 Size MD500 "G-Jive Blue" GPS Stabilized Helicopter RTF Discussion Thread
    • 8218
    MD500 "G-Jive Blue" 250 Size GPS Stabilized Helicopter - RTF from RotorScale - RSH1029-001
    The RotorScale MD500 "G-Jive Blue" packs serious scale fidelity into a compact, GPS-stabilized platform that’s as fun to fly as it is to admire. From the opening cabin doors to the fully detailed interior and 5-blade rotor head, this is far more than your average RTF heli—it’s a standout scale replica that turns heads before it even lifts off.
    Built-in GPS stabilization gives you confidence in every flight, whether you're hovering inches off the deck or running automated flight patterns. Position hold, one-touch return-to-home, and auto landing functions make it approachable for newer pilots, while the robust airframe, bright LED nav lights, and crisp flight response keep experienced pilots engaged.
    With molded scale details, tinted windows, working lights, and a full cockpit layout inside, the MD500 "G-Jive Blue" delivers unmatched realism at this size. And with everything you need included in the box—transmitter, battery, charger, and hard case—you’ll be ready to fly the moment it arrives.
    Iconic Style, Ready to Fly
    The MD500 “G-Jive Blue” stands out with its bold finish and unmistakable profile. Fully assembled and factory-tuned, it's ready for flight right out of the box.
    Fly Right Out of the Box!
    No setup, no hassle - everything is factory-installed and ready to go. Charge the included LiPo and transmitter, install the rotor blades, power on, and you’ll be airborne in minutes with the MD500 at your command.
    Scale That Goes Deeper
    The opening cabin doors reveal a fully molded cockpit features pilot seats, controls, and instrument panel detail. It’s true scale realism rarely found in this class of helicopter.
    Smart Flying Made Easy with GPS
    With GPS-assisted flight, position hold and return-to-home functions are just a switch away. Fly with confidence, even if you're just starting out.
    Scale 5-Blade Flybarless Rotor
    The MD500’s 5-blade flybarless rotor head delivers smooth, stable performance while maintaining authentic scale appearance. Each hover and maneuver feels realistic, giving you precision control wrapped in scale detail.
    Refined Exterior Detail
    Carefully molded exterior details enhance realism from every angle. Every line and surface is designed to elevate the scale presence in the air and on the ground.
    • Completely ready-to-fly package—includes helicopter, transmitter, smart battery, charger, and transport case
    • Detailed MD500 fuselage with molded surface panel lines, clear windows, and factory-applied “G-Jive Blue” livery
    • Full cockpit interior with visible seats, control panel, and cyclic/collective sticks
    • Opening side cabin doors for added scale realism
    • Functional LED navigation lights for improved visibility and enhanced presence in the air
    • Advanced GPS-assisted flight controller enables position hold, one-button return-to-home, circle flight, figure-8 mode, and auto landing
    • Multiple selectable flight modes: GPS Stabilization, Visual Stabilization (optical flow), and Manual
    • 5-blade flybarless rotor head for improved stability and scale appearance
    • Powerful brushless main and tail motors for reliable and smooth performance
    • Pre-installed electronics: motors, servos, flight controller, and receiver
    • Included 11.1V 3500mAh LiPo battery with approx. 15-minute flight time
    • USB-C charging system included for convenient and modern charging compatibility
    • 2.4GHz transmitter with dedicated switches for flight mode, auto return, and demo functions
    • Rigid, lightweight airframe construction for balanced performance and everyday flying durability
    • Includes spare tools, accessories, and a protective carry case for storage and transport
    • RotorScale MD-500 “G-Jive Blue” 250 Size Helicopter
    • Factory-installed brushless motor, ESC, and stabilization system
    • 2.4GHz 6-channel transmitter
    • 3S LiPo flight battery
    • USB balance charger
    • Tools and accessories for maintenance
    • Detailed instruction manual
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Intermediate
    BUILD TIME : 10 Minutes
    Class / Size 250 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 485mm (19.1") X 190mm (7.5”) X 127mm (5.0")
    Flying Weight 700g (24.7 oz) with battery
    Main Rotor Diameter 437mm / 17.2”
    Main Rotor Blade Length 210mm / 8.27”
    Tail Rotor Diameter 73mm / 2.87”
    Tail Rotor Blade Length N/A
    Tail Drive Type Factory-installed brushless motor
    Cyclic Servos Digital metal gear servos
    Tail Servo N/A (direct drive system)
    Power System Factory-installed direct drive brushless motor
    Electronic Speed Control Integrated brushless ESC
    Recommended Battery 3S 3500mAh LiPo battery
    Required Radio 2.4GHz Radio (included)
    Skill Level Intermediate
    Build Time Less than 10 minutes
    • 2818
    • Arlington, TX
    Any chance of a gyro-only version of this one (no GPS?). Looks excellent!
    • J Nelson
      • Oct 2023
      Just ordered, looking forward to going from drones and EDF’s to helicopters 🤞🏻🤞🏻
      • Jetman64
        • Jun 2017
        • 113
        Just ordered this beautiful Helicopter (my first RC Heli), and I’m excited to get started in the RC Heli world. Now it’s time to start reading about them, to get ready. I worked AH-1F and AH-64A helicopters when I was in the Army, back in the 80’s. My long term plan, is to sell everything that’s related to fixed wing RC, and hopefully build a Vario AH-1 turbine Helicopter next year. But for now, it’s straight to the training n learning for the next year.
