Official Rotorscale 150 Size OH-58C Kiowa Gyro Stabilized Helicopter RTF Discussion Thread
    • 8228
    OH-58C Kiowa 150 Size Gyro Stabilized Helicopter - RTF from Rotorscale - RSH1026-001
    The RotorScale OH-58C Kiowa brings the legendary U.S. Army scout helicopter to life in a detailed 150 size ready-to-fly scale package. Modeled after the B206 airframe adapted for military service, this Kiowa captures the unmistakable profile and battlefield presence of the real aircraft in a compact, easy-to-fly model.
    Equipped with 6-axis gyro stabilization and an optical flow positioning system, the Kiowa maintains rock-solid hovering performance and steady forward flight even in the hands of less experienced pilots. Takeoffs and landings are simplified with one-touch auto functions, while advanced pilots can explore inverted flight at the push of a button.
    Finished in a factory-applied scale camouflage scheme and complete with LED navigation lights and optional decals, the Kiowa turns heads wherever it flies. Best of all, it arrives completely ready-to-fly with transmitter, battery, charger, and accessories included—just add AA batteries and your mission is ready for launch.
    Authentic OH-58C Kiowa Detail
    Every molded panel line captures the rugged character of the U.S. Army’s iconic scout helicopter. The factory-applied camouflage finish instantly conveys battlefield realism, making this little heli look the part before it ever lifts off. Optional decals let you customize your Kiowa with authentic markings to create a display-worthy scale model that also flies.
    Ready-to-Fly Right Out of the Box
    No building, no setup headaches—everything you need is included. The transmitter, battery, charger, and helicopter come pre-configured, so you can go from box to flight line in minutes. Just charge the LiPo, install four AA batteries in the transmitter, and launch your first mission with total confidence.
    Scale 2-Blade Flybarless Rotor
    The flybarless two-blade rotor head is engineered for both realism and performance. Its streamlined design reduces drag and complexity, while delivering smooth, precise control in every maneuver. From steady hovers to forward flight, the Kiowa’s rotor system makes it look and feel like the real thing in miniature.
    6-Axis Gyro with Optical Flow
    Flight stability is built right in thanks to advanced 6-axis gyro technology. The optical flow sensor actively scans the surface below, locking the helicopter into position with incredible accuracy. Together, these systems help eliminate drift, making hovering effortless for beginners and rock-solid for scale flyers.
    One-Touch Auto Takeoff and Landing
    Takeoffs and landings are no longer stressful! With the press of a button, the Kiowa lifts smoothly into a steady hover or touches down with precision. These auto functions handle the hardest parts of flying for you, so you can focus on learning control and enjoying the flight. Even first-time pilots can look like pros right out of the box.
    Inverted Flight at the Push of a Button
    The Kiowa doesn’t just fly scale, it brings the fun too. Engage one-key inverted mode and watch as the helicopter flips over and keeps flying upside down with full control. It’s a jaw-dropping feature that turns heads at the field and delivers aerobatic excitement without the steep learning curve.
    • Completely ready-to-fly package includes everything needed to start flying -- simply charge the battery, insert 4x AA batteries into the transmitter and fly!
    • Finely detailed scale fuselage replicates the OH-58C Kiowa with molded panel lines and rivet detail
    • Factory-applied camouflage finish with optional decal set allows for authentic scale realism
    • Scale 2-blade flybarless main rotor blade system
    • 6-axis gyro stabilization ensures smooth, stable flight in all conditions
    • Optical flow positioning system locks the helicopter in place when hovering
    • One-touch auto takeoff and landing functions simplify operation for new pilots
    • One-key inverted flight mode makes inverted flight possible at the press of a button
    • LED navigation lights and taillight improve visibility and enhance scale presence
    • Durable rotor head and tail rotor system ensures reliable performance
    • Factory-installed servos, main motor, and flight controller for quick setup
    • USB-C charging system for convenient charging from computer or power bank
    • Reliable 2.4GHz control system ensures strong, interference-free connectivity
    • Lightweight yet robust construction designed for everyday flying durability
    • Spare tools and accessories included to keep your Kiowa mission-ready
    • RotorScale OH-58C 150 Size Helicopter
    • Factory-installed brushless motor, ESC, and stabilization system
    • 2.4GHz 6-channel transmitter
    • 2s LiPo flight battery
    • USB balance charger
    • Tools and accessories for maintenance
    • Detailed instruction manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : less than 10 minutes
    Scale 1/40
    Class / Size 150 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 320mm (12.6") X 60mm (2.4”) X 115mm (4.5")
    Weight (without battery) 114g (4oz)
    Main Rotor Diameter 306mm / 12"
    Main Rotor Blade Length 140mm / 5.5"
    Tail Rotor Diameter 52mm / 2"
    Tail Rotor Blade Length N/A
    Tail Drive Type Factory-installed brushless motor
    Cyclic Servos 4.3g digital metal gear servos
    Tail Servo N/A (direct drive system)
    Power System Factory-installed direct drive brushless motor
    Electronic Speed Control Integrated brushless ESC
    Recommended Battery RotorScale 2S 350mAh Battery
    Battery Compartment Size (L x W x H) 45mm (1.77”) X 25mm (1.0”) X 17mm (0.67”)
    Required Radio 2.4GHz Radio (Included)
    Skill Level Beginner
    Build Time Less than 10 minutes
    Recommended Environment Indoors/Outdoors
