Official RotorScale 100 Size Airwolf Gyro Stabilized Helicopter RTF Discussion Thread
Name:	Airwolf 100 10.jpg
    Airwolf 100 Size Gyro Stabilized Helicopter - RTF from RotorScale - RSH1028-001
    Step into the cockpit of one of television’s most legendary helicopters with the RotorScale Airwolf 100 Size Gyro Stabilized Helicopter. Faithfully styled after the iconic aircraft from the Airwolf TV series, this compact model combines striking scale detail with cutting-edge flight technology to deliver an experience that’s as exciting as it is approachable.
    Designed for pilots of all skill levels, the Airwolf features an advanced 6-axis gyro and optical flow positioning system that work together to provide exceptional stability and smooth, confidence-inspiring control. Whether you're flying for the first time or just looking for a relaxing, scale flying experience, the Airwolf makes every flight feel effortless.
    Arriving completely ready-to-fly, setup is simple—just charge the included battery, add four AA batteries to the transmitter, and you're ready for takeoff. One-touch takeoff and landing functions remove the guesswork, making it easy to get airborne and back down safely every time.
    Its compact size makes it ideal for indoor flying in large indoor spaces, while still capable of handling light winds in outdoor conditions. From the court to the backyard, the RotorScale Airwolf delivers legendary style and smooth performance wherever you fly.
    Ready to Fly in Minutes!
    The RotorScale Airwolf comes fully assembled and flight ready right out of the box. Just charge the included battery, install AA batteries in the transmitter, and take to the skies.
    Smooth, Stable Flight with 6-Axis Gyro
    Built-in 6-axis stabilization helps keep the Airwolf steady and responsive, making every flight feel controlled and predictable.
    Confident Hovering with Optical Flow Positioning
    An onboard optical flow sensor assists with position hold, allowing for steady hovering and easier control—perfect for building confidence.
    Airwolf Comes to Life
    Inspired by the legendary TV series, this model captures the unmistakable presence of Airwolf in a compact, flyable form.
    Impressive Scale Detail Throughout
    Despite its small size, the Airwolf features a detailed scale fuselage with clean lines, molded panel lines, and exhaust details that make it stand out in it’s class.
    Fly Virtually Anywhere with a Convenient Size
    Its compact size makes the Airwolf easy to fly in large indoor spaces while still being capable outdoors in calm conditions.
    • Completely ready-to-fly with everything included. Simply add 4 AA batteries to the transmitter and fly after charging the included battery
    • Advanced 6-axis gyro stabilization delivers exceptional stability and smooth, predictable control for pilots of all skill levels
    • Integrated optical flow sensor helps maintain position for steady hovering and increased confidence in flight
    • Highly detailed scale fuselage captures the unmistakable look of the Airwolf from the classic TV series
    • One-touch takeoff and landing functions make it easy to get airborne and return safely with the push of a button
    • 3.7V 220mAh battery charges conveniently using a modern USB-C connection
    • Reliable 2.4GHz control system provides strong, interference-resistant signal performance
    • Compact size, ideal for indoor flying in large open areas, as well as outdoor flight in calm conditions
    • RotorScale Airwolf 100 Size Gyro Stabilized Helicopter – RTF
    • 2.4 GHz Transmitter
    • 1x Flight Battery
    • 1x USB to USB-C Charge Cable
    • Spare Tail Rotor
    • Screwdriver Set
    • Instruction Manual
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Class / Size 100 Size
    Power Type Electric
    Rotor Type Collective Pitch
    Body Material Plastic
    Overall Size (L x W x H) 242mm (9.6 in) x 67mm (2.6 in) x 77mm (3.03in)
    Flying Weight 55g (2oz)
    Main Rotor Diameter 227mm (8.9 inches)
    Main Rotor Blade Length 98mm (3.9 inches)
    Tail Rotor Diameter 8mm (1.5 inches)
    Tail Rotor Blade Length N/A
    Tail Drive Type Coreless Brushed Motor
    Cyclic Servos 3 x 2g Digital Servos
    Tail Servo N/A
    Power System Coreless Motor
    Electronic Speed Control 2A, 2-in-1 ESC
    Recommended Battery 1S 220mAh LiPo (Included)
    Required Radio 2.4GHz Radio (Included)
    Skill Level Beginner
    Build Time Less than 10 minutes
    Recommended Environment Large Indoor Area or Outdoor Area in Calm Winds
  • BongRTM
    • Feb 2020
    • 3
    • Colorado Springs
    Overall, excellent small heli for indoor flying! I’m an Airwolf fan and It adds perfectly to my collection! The details are excellent! Almost exactly as the life size…unlike most scale Airwolf models this small!
    I had to change a couple of things (see pictures): Added side guns/cannon, relocated the fuel port stickers, added white window ports, added mock jet engines, added missile launcher on the bottom, added pitot tubes and refueling port, added radar pod on top of the nose, reshaped the horizontal stabilizers (too big), repainted the white over the jet engines to black, painted batteries white to match bottom paint scheme, painted exhaust ports gray and painted red stripes on the tail skid.
    2 Issues:
    1) It is not collective pitch as stated in the specifications. It is fixed pitch.
    2) Because of the altitude where I live (Colorado Springs, 6,850ft), it mostly flies only 2-3 inches above the ground. For the first 2.5 min, it flies normally, 3+ feet off the ground. I flew it before and after the modifications…flew the same…the added weight is not the issue. I have yet to fly it at lower altitudes, but I'm sure it'll fly great!
