Rotorscale Cobra Super Scale 470 Helicopter
  • BigMike1963
    • Jan 2023
    Has anyone had an issue with the flight control changing from green to blue when you switch the transmitter to run
    • 8772
    I've not noticed. Perhaps it depends on which position you have the "GPS/ANGLE/MANUAL" and "OFF/RTH" switches. Mine are all UP when the TX is powered on and only the "Run/Cut" switch is moved down (to cut) before using the left stick to the inside and down for several seconds to ARM it before going to RUN. After I plug the battery in (switch to CUT), I let it sit undisturbed for about a minute so it can acquire all the necessary satellites. I recall the light flashes green slowly (as opposed to quickly as it searches for all the satellites). By this time, I'm no longer near the heli to see what the light is doing.
