Bring one of the most iconic attack helicopters ever built to your flight line with the RotorScale AH-64 Apache 160 Size Helicopter. Every inch of the fuselage is packed with super-scale detail, from crisp panel lines and rivet work to scale armament and a detailed cockpit complete with pilot figures, so it looks every bit as menacing sitting on the pad as it does in the air.
Looks aside, this Apache flies as good as it looks. A 6-axis gyro and optical flow positioning system work together behind the scenes to deliver smooth, confident control at any skill level, while one-touch auto takeoff and landing take the guesswork out of every flight. Feeling adventurous? One key inverted flight lets you flip the script and push your flying further whenever you're ready.
Setup is just as effortless as the flying. The main motor, tail motor, flight controller, and servos all come factory installed, so you can go from box to flight line in minutes. Charge the included 2S LiHV battery over USB-C, drop four AA batteries in the transmitter, and you're airborne as quickly as it takes to charge the battery. LED navigation lights add scale realism and make the Apache easy to track in flight, while lightweight, robust construction keeps it flying session after session.
Whether you're building a scale military helicopter collection or just want a helicopter that turns heads on looks and performance alike, the RotorScale AH-64 Apache delivers.
| Ready to Fly in Minutes! The RotorScale AH-64 Apache comes fully assembled and flight ready right out of the box. Just charge the included flight battery, install AA batteries in the transmitter, and take to the skies. |
| Super Scale Detail, Down to the Rivets From crisp panel lines to scale armament, the Apache's fuselage is built with a level of detail that holds up to a close look, not just a passing glance. |
| A Cockpit Built for the Details A detailed cockpit complete with pilot figures adds another layer of realism, bringing this Apache to life on the ground and in the air. |
| Smooth, Stable Flight with 6-Axis Gyro Built-in 6-axis stabilization helps keep the Apache steady and responsive, making every flight feel controlled and predictable. |
| Confident Hovering with Optical Flow Positioning An onboard optical flow sensor assists with position hold, allowing for steady hovering and easier control — perfect for building confidence. |
| Small Frame, Big Presence At just 310mm long, the Apache packs serious attitude into a size that's easy to fly almost anywhere. |
| Takeoff, Land, and Even Fly Inverted at the Touch of a Button One-touch auto takeoff and landing make every flight easy to start and end, while one key inverted flight lets more experienced pilots take things further. |
| Scale Rotorhead, Real Flight Appearance A scale 4-blade flybarless rotorhead delivers a realistic look along with smooth, responsive flight characteristics. |
- Completely ready-to-fly. Simply charge the included flight battery, install 4 AA batteries in the transmitter, and fly
- Extremely detailed, super-scale fuselage with crisp panel lines, rivet detail, and scale armament
- Detailed cockpit featuring pilot figures for added scale realism
- Advanced 6-axis gyro stabilization delivers exceptional stability and smooth, predictable control for pilots of all skill levels
- Integrated optical flow sensor helps maintain position for steady hovering and increased confidence in flight
- One-touch auto takeoff and landing functions make it easy to get airborne and return safely with the push of a button
- One key inverted flight lets experienced pilots push their skills further with a single control input
- LED navigation lights add scale appearance and improve visibility during flight
- Scale 4-blade, flybarless rotor head for a realistic look and smooth flight characteristics
- Factory-installed main motor, tail motor, flight controller, and servos for quick, hassle-free setup
- Convenient USB-C charging system for the included flight battery
- Reliable 2.4GHz control system provides strong, interference-resistant signal performance
- Lightweight yet robust construction built to handle everyday flying durability
- Spare tools and accessories included for easy maintenance
- RotorScale AH-64 Apache 160 Size Helicopter – RTF
- Factory-installed brushless main motor, ESC, and stabilization system
- 2.4GHz 6-Channel Transmitter
- 2S LiHV Flight Battery
- USB Balance Charger
- Tools and accessories for maintenance
- Detailed Instruction Manual
- Four (4) AA size batteries for the radio transmitter – we recommend GP Super Alkaline 1.5V AA Batteries (4 pack)
AGE LEVEL : 14 and Up
SKILL LEVEL : Beginner
BUILD TIME : Less than 10 minutes | Scale | 1/48 |
| Class / Size | 160 Size |
| Power Type | Electric |
| Rotor Type | Flybarless |
| Body Material | Plastic |
| Overall Size (L x W x H) | 310mm (12.2 in) x 97mm (3.8 in) |
| Weight (with battery) | 150g (5.3oz) |
| Main Rotor Diameter | 308mm (12.1 inches) |
| Main Rotor Blade Length | 135mm (5.3 inches) |
| Tail Rotor Diameter | 52mm (2 inches) |
| Tail Rotor Blade Length | N/A |
| Tail Drive Type | Brushed Motor |
| Cyclic Servos | 2g digital metal gear servos |
| Tail Servo | N/A (direct drive system) |
| Power System | Factory-installed direct drive brushless motor |
| Electronic Speed Control | 10A ESC with 1A BEC |
| Recommended Battery | 2S 7.7V 560mAh LiHV (included) |
| Required Radio | 2.4GHz Radio (Included) |
| Skill Level | Beginner |
| Build Time | Less than 10 minutes |
| Recommended Environment | Indoors/Outdoors |
.png)
