Official Rotorscale MH-6 Little Bird 180 Size Gyro Stabilized Helicopter RTF Thread
    • 8238
    MH-6 Little Bird 180 Size Gyro Stabilized Helicopter - RTF from Rotorscale - RSH1030-001
    The MH-6 Little Bird has carried U.S. Army special operations forces into and out of high-risk objectives for decades, built to fly low, fast, and unnoticed with troops riding the external bench platforms. The RotorScale MH-6 Little Bird brings that same mission profile roaring to life in scale, complete with armed figures riding the bench platforms, just like the real thing, along with crisp panel lines and rivet detail that give the fuselage serious scale presence.
    And it flies every bit as good as it looks. A 6-axis gyro and optical flow positioning system work together behind the scenes to deliver smooth, confident control at any skill level, while one-touch auto takeoff and landing take the guesswork out of every flight, so you can focus on flying.
    Getting airborne is just as effortless. With the main motor, tail motor, flight controller, and servos already factory installed, all that's left is screwing on the landing gear and mounting your crew before you charge the battery, strap in your team, and take command of your own special operations mission, low and fast across the backyard or battlefield of your imagination. Lightweight, rugged construction keeps this Little Bird flying, mission after mission.
    For collectors and pilots who want a helicopter that stands out on looks alone, the RotorScale MH-6 Little Bird delivers a level of scale military detail that's hard to find anywhere else.
    Mission Ready in Minutes
    The landing gear simply screws on and the figures mount in place, then it's just charge the battery and drop AA batteries in the transmitter to take to the skies.
    Painted Scale Military Figures Ride Along
    Armed figures riding the bench platforms bring the crew, and the mission, to life, a detail few RC helicopters offer.
    Scale Detail Down to the Rivets
    Crisp panel lines and rivet detail give this Little Bird serious scale presence, on the ground and in the air.
    Smooth, Stable Flight with 6-Axis Gyro
    Built-in 6-axis stabilization helps keep the Little Bird steady and responsive, making every flight feel controlled and predictable.
    Confident Hovering with Optical Flow Positioning
    An onboard optical flow sensor assists with position hold, allowing for steady hovering and easier control — perfect for building confidence.
    Full Mission Control, One Touch Away
    One-touch auto takeoff and landing puts full mission control at your fingertips, launching you into the air and setting you down safely with the push of a button.
    Scale Rotorhead, Real Flight Feel
    A scale 5-blade flybarless rotorhead delivers a realistic look along with smooth, responsive flight characteristics.
    Small Frame, Big Presence
    At just 335mm long, the Little Bird packs serious scale character into a size that's easy to fly almost anywhere.
    • Nearly ready-to-fly out of the box. The landing gear screws on and the figures mount in place, then it's just charge the battery, drop 4 AA batteries in the transmitter, and take to the skies
    • Comes loaded with painted scale military figures, turning every flight into a scene straight out of a special ops mission
    • A highly detailed fuselage with crisp panel lines and rivet detail gives this Little Bird serious scale presence
    • Advanced 6-axis gyro stabilization keeps every flight rock-steady, giving pilots of all skill levels smooth, confident control
    • An integrated optical flow sensor locks in a steady hover, so you can hold position with ease and fly with total confidence
    • One-touch auto takeoff and landing puts full mission control at your fingertips, launching you into the air and setting you down safely with the push of a button
    • A scale 5-blade, flybarless rotor head delivers a striking scale look paired with smooth, authentic flight characteristics
    • Factory-installed brushless main motor, brushless tail motor, flight controller, and servos mean less setup and more time in the air
    • A fast, convenient USB-C charging system gets you back in the sky in no time
    • A reliable 2.4GHz control system delivers a strong, interference-resistant signal you can count on, mission after mission
    • Lightweight yet rugged construction is built to keep flying, flight after flight
    • Spare tools and accessories are included so you're always ready for the next mission
    • RotorScale MH-6 Little Bird 180 Size Helicopter – RTF
    • Factory-installed brushless main motor, ESC, and stabilization system
    • 2.4GHz 6-Channel Transmitter
    • 2S LiPo Flight Battery
    • USB Balance Charger
    • Tools and accessories for maintenance
    • Detailed Instruction Manual
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 30 Minutes
    Scale N/A
    Class / Size 180 Size
    Power Type Electric
    Rotor Type Flybarless
    Body Material Plastic
    Overall Size (L x W x H) 335mm (13.2 in) x 126mm (5.0 in)
    Weight (with battery) 290g (10.2oz)
    Main Rotor Diameter 325mm (12.8 inches)
    Main Rotor Blade Length 136mm (5.4 inches)
    Tail Rotor Diameter 56mm (2.2 inches)
    Tail Rotor Blade Length N/A
    Tail Drive Type Brushless Motor
    Cyclic Servos 2g digital metal gear servos
    Tail Servo N/A (direct drive system)
    Power System Brushless Motor
    Electronic Speed Control 12A with 4A BEC
    Recommended Battery 2S 1200mAh LiPo (included)
    Charge Time Approximately 90 minutes
    Flight Time Approximately 9 Minutes
    Required Radio 2.4GHz Radio (Included)
    Skill Level Beginner
    Build Time Less than 30 minutes
    Recommended Environment Outdoors in Calm Conditions
