The manual for the t45 90mm does not tell you exactly how to connect the esc to your rx.I think the wires (2) with the ferret ring go to the aux channel but do i need to disconnect the red wire on the red, white and black wire to the throttle channel or does it plug in with all 3 wires intact since the is no internal bec? I bought on of those bec eliminator cables but I don't think it's necessary if i don't need to pull the red wire on the throttle connection. Also the pdf for the esc has the brake enabled by default; is that correct?
Any thoughts, or assistance would be appreciated.
Thanks,
Air5
Thanks,
Air5
