ESC'S won't bind
  • K9bearbpd
    ESC'S won't bind
    Dynam Messerschmitt ESC- I've been attempting to bind my twin ESC's, I get a constant beep beep beep. I'e tried the throttle all the way up and down with no luck. Is there a specific set up for the red, blue and black wires from the motor to the ESC?
  • fhhuber
    • Aug 2015
    • 1476
    Could be reversed plug at the RX, making the ESC not see a proper RX output.
    As for ESC to motor, changing which wire plugs to which on the motor can reverse the motor, but it would still run.
    Please remove the prop while you work to solve the issue. You do not want the motor to start unexpectedly with the prop on.
      No, only thing swapping those will do is reverse the motor rotation direction. Make sure your wires to the receiver are in the correct polarity. You're probably not getting power to the receiver. What experience do you have with rc aircraft?
        • 8750
        But is your throttle trim tab all the way down? Are you standing several feet away from the plane when you are binding?
        • fhhuber
          • Aug 2015
          • 1476
          BTW.. they DO test at the factory to ensure correct motor rotation. I have never had one out of box with reversed motor direction.
          There are a few things that can keep the ESC from arming. I have had to resort to the ESC programming card a couple of times. (highly recommend getting one ... you don;t use it often but if yo accidentally reprogram it randomly, you don't want to do it by beep code)
