Syncing twin motors
  • Mrdronenut
    • Mar 2018
    • 27
    Syncing twin motors
    When i got my Dynam Turbo jet,it had either a bad esc,or bad port motor. MRC sent me both. I installed the replacement esc's on my Dynam Turbo jet,did the initialization,and found it to be a bad motor after all. So,i put the new motor in,and the port motor still wants to "stutter"on "throttle up". I've tried re-initializing the esc's again,setting the timing,restoring back to factory specs. No good. Still a 'stutter"on my port motor!!!! HELP
    • 8751
    The stuttering on some Dynam motor/ESC set ups is a known ailment. Have you seen Ryan's video on how to resolve this?
    • gooniac33
      The Original Gooniac
      • Jun 2016
      • 1047
      There are a couple ways to fix this. The complicated way is listed above and there is nothing wrong with it. However all you need is the programming card for the esc to make sure that the timing is set to low and then set the throttle range.
      • Mrdronenut
        • Mar 2018
        • 27
        Thanks y'all. I've tried the 1st way. I'll order the card. Tbanks again.
          • 8751
          Originally posted by mensbrag
          I have already attempted the first option. Sure, I'll place an order for that greeting card.
          "Greeting card", huh? You have no idea what this thread is about. You're just setting us up for spam. Found it and reported.
          WARNING! THIS GUY HAS ALTERED THE LINK THAT GOONIAC PUT UP. DO NOT CLICK ON THE ONE HE QUOTED. IT COULD BE MALICIOUS AND PHONEY.
