Greetings,
I've given this form a quick look but can't find any data on the actual amp draw of the fan units with the recommended MotionRC setups.
What I'd like to learn is what is the actual amp draw (with say a 10% variability) for the stock 12 bladed 80mm fan, outrunner on 6 cells. I know the spec's show that the setup needs an 80 amp ESC. So I assume the current draw is less than 80 amps. I'd also like to know what is the current draw of the 12 bladed 80mm fan, 1750kv inrunner on 6 cells. Again the spec's say to use a 100 amp ESC.
Being as both motors are rated at 1750kv I assume the outrunner is drawing close to the max 80 amps and that with the more efficient (less rpm drop at higher currents) inrunner that the current goes over the 80amp limit necessitating the upgrade to a 100 amp ESC.
I ask because I like to spec my electrical equipment to have about 20% head room. Just reading the spec'c has me scared a bit with the 80 amp ESC. Now if the actual current draw for the outrunner is in the low 70's I'd be comfortable with the stock set up.
Now if I need to go with a larger ESC to be comfortable I might find it worth the cost to upgrade the whole system to the 1750KV inrunner.
TIA,
Konrad
TIA,
Konrad
