Does anyone have this charger and if so, what does Warning! Supply 50% of DOD. Thanks.
Powerlab 8
Tags: None
I don't have this charger, but i found this on page 45 of the online manual. Took me all of 2 minutes to find it online.
Show Warning at 50% DOD: If checked, PowerLab 8 measures battery voltage when first connected. If the battery is below 50% depth of discharge (below that point, most flooded Lead Acid batteries are damaged), PowerLab 8 beeps and issues a warning. Press the BACK button to cancel the operation on the PowerLab 8, then correct the situation. (You could press the ENTER button to proceed, but this is not recommended.) -
Thanks for finding this but all 12 of my 6s batteries can’t be bad lol I just hit enter and charge with no issues.I don't have this charger, but i found this on page 45 of the online manual. Took me all of 2 minutes to find it online.
http://www.revolectrix.com/support_docs/item_1340.pdfComment
THE DOD is in reference to the supply battery voltage, which is based on a lead acid battery. What are you using to power your charger? DC supply, or lead acid battery?Comment
