FMS 85A ESC - FMS-DT85
  • Corwin51
    • 4
    Does anyone have a manual for the FMS 85A ESC that comes with the FMS 1700mm Corsair? I got my receiver set up and the throttle line from the ESC going to channel 3. But when I connect my battery the ESC goes into programming mode and won't come out. I tried powering up with the throttle at max and then backing off when I heard the first two tones (saw this step in a video). But still goes into programming mode when powered up after that.
    Thanks.
  • Corwin51
    • 4
    As Carlos Mencia would say.... Dee Dee Dee!! Had to reverse the throttle channel. Would still appreciate a manual if anyone has one.
      http://www.fmsmodel.com/predator-esc-85a-3798
      • Swing
        • 9
        Does the FMS Predator have a program card available? Or maybe a ZTW Gecko one will work?
          This should do the trick for ya
          • Swing
            • 9
            Thanks! I see in the instructions it has many more program options. For them I guess you have to use the beep beep?
