This may be a long post so I'm splitting it into 2. Part 1:
When I first got into EDF's a couple of years ago I used exclusively the Admrial 6000 Pro 50C but lately felt I wasn't getting the most our of the EDF is some jets, therefore, over the last 4 months I have been on a quest to get more take-off thrust (flying off of grass) and flight time, specifically on the F-4, F-16, F-18 and SU-30. Several people suggested using different batteries, RC Geek uses the Roaring Top 6250 35C in the stock F-4, Brinka (a good friend and exceptional EDF pilot) uses HRB, Phantom suggested the Hobbystar 8000 for better flight times and others suggested the RT 5500 70C for the SU-30, so the chase was on. In that effort, I purchased a Progressive RC internal resistance meter to test the actual C and used my GT power meter (use up till then only to match wooden Xoar props to certain planes and make sure I wasn't over extending an ESC). So here are some of the results. Please keep in mind that I'm no LiPo or EDF expert and I could barely afford buying the batteries I did, but I'm sure there are many other ones out there that work fine so take everything I say here with a "grain of salt". If you battery or EDF is not included, please send me one and I'll test it out, but if it's really good, don't expect to get it back anytime soon.
The JUDGES:
1) For actual C results, the Progressive IR meter. Please note that the resulting C from the meter, according to the maker, is VERY conservative and he even adds a factor of 1.5 to get the most "likely" C. All batteries tested were fully charged (makes a difference), had been recycled enough times to reach optimum performance and tested at 72 degrees (actually the most important factor in consistently calculating IR and actual C). 2) The GT Power meter to register Ah and Watts drawn under load, hooked up to a fully charged battery (actually used several of the "best" C tested ones from each group) and bench tested on each fan by evenly increasing the throttle from 0 to full, holding it for 8 seconds, then dropping it back to 0 and reading the results. The power draws on a free flying jet will actually be lower than on held on the bench due to air being forced into the fan from flight, vs having to suck "dead" air on the bench.
The CONTENSTANTS:
1) 8-Roaring Top 5500 70C: cost $120, weight 825 g, Actual C 22C, likely C: 33
2) 12-Admiral 6000 50C Pro: cost $124, weight 827 g, Actual C 17C, likely C: 25
3) 4-HRB 6000 50C-100C burst: cost $84, weight 830 g, Actual C 22C, likely C: 33
4) 14-Roaring Top 6250 35C: cost $93, weight 790 g, Actual C 18C, likely C: 27
5) 6-HobbyStar 8000 100C, cost $179, weight 908 g, Actual C: 18C, likely C: 27 (man I'm seriously broke now after these)
Apparently, calculating actual C is a tricky business and even with this meter based on 3 guys extensive research, it can't determine the exact C, however, it can tell which batteries have a lower IR (and higher C) versus others, the actual mAh in each cell and the IR in each cell is shown, alerting me to a potential "bad" battery or one that may be ready to "kick the bucket".
On to actually testing each with EDF's in next post. TBC
The JUDGES:
The CONTENSTANTS:
