Is this a sign of a faulty cell ?
  • Simon Bee
    • Oct 2021
    • 135
    • Leeds UK
    I’ve got 4 Admiral 4S 4000s which I’ve used regularly for the last 6 months.
    I only use them in my WOT4 and a couple now show 14 % after only about 4-5 mins flying. It’s never 15% or 20% but always the same figure 14% which seems strange.
    They’re not puffy and the resistances are low, just wondering whether it’s time to get rid and why is it always 14% ??
  • Simon Bee
    • Oct 2021
    • 135
    • Leeds UK
    Just wondering whether it’s my Overlander battery checker. When the voltage reaches about 15v, the battery checker jumps from 14% to about 30%
    • RRHandy
      Instructor Pilot
      • 895
      • Lilburn GA
      I don't rely on the percent value of any of the checkers, I look at what the cell values are, 3.7 to 3.8 per cell and that is the value that is most important for storage and that is where I like land my planes so I test till I hit that #
      To answer your question, that depends on if you flew longer or used more throttle during the flight.
      AMA 424553
      • Simon Bee
        • Oct 2021
        • 135
        • Leeds UK
        Thanks for the reply. The checker is showing correct voltage but wrong percentage. At 15 v for a 4S it should say about 27% capacity NOT 14%. At 15v and below it can’t calculate the percentage.
          • 5401
          If you check with a voltmeter what does it say each cell is?
          • RRHandy
            Instructor Pilot
            • 895
            • Lilburn GA
            That is why I don't pay any attention to % I go with cell voltage.
            P.S. I look at IR when charging and make sure that is balanced also.
            AMA 424553
            • Alan 3D
              • Oct 2022
              • 26
              You're obviously have a bad meter cell checker.
              • Alan 3D
                • Oct 2022
                • 26
                My capacity cell checker will not read one cell if it is below a certain voltage after a flight giving a 3.9 volts which is incorrect 99% of the time. This is because the meter is only designed for two cell or higher.
