LIFE Batteries
  • Mad Baron
    132 Aviation
    • 547
    • McMinnville Tn.
    LIFE Batteries
    I have two new Admiral 210mah LiFe batts and they will not take a charge. The first charge on these batts was 14.95mah and 1460mah I let them rest for 30 minutes and performed a storage charge 97mah and 86mah. after resting for 30 minutes the second charge only put in 126mah and 133mah. I installed one of these batts in my glow powered plane and exercised the 5 servos for 10 minuets. I checked the battery and it showed 91% after charging and after 10 minuets it was showing 61% charged. I dont trust these batteries at all. Anyone have any thoughts?
    • 5401
    I don't understand your numbers or process. 14.95 and 1460? Is that right with the decimal point? 1460 into a 210? I don't see a 210 on Motions site... Then you don't discharge, you say let them rest and you are charging again? then rest and charge again? So you put 14.95 + 97 + 126 = 237.95 in one? I think your numbers for #2, 1679mAh total in, may be right for a 2100.
    You put it in a plane.. Five servos, what kind of servo's, what surfaces (retracts?) etc? After 10 minutes of use in the plane it shows 61% from a 210mAh LiFe... It could be right. For a 2100 it's not right.
    • Mad Baron
      132 Aviation
      • 547
      • McMinnville Tn.
      I meant 2100.
        • 5401
        Okay... And the servos, high power? Mini? Micro?
        And the 61% is on a LiFe setting or are you using a LiPo checker? Life drop off from full voltage quickly to a stable usage voltage. Different than a LiPo plus the LiPo and Life are different voltages and a checker translates cell voltage to a percentage.
        • Mad Baron
          132 Aviation
          • 547
          • McMinnville Tn.
          The percentage is on the LiFe setting of the checker. The servos are standard Futaba S3003. When I put the LiFe on storage charge after the test on my plane it was on the charger for 3 minutes when the charger showed it was finished with the storage charge. I never had that sort of problem with my lipo batteries.
