Hello guys,
I have the Freewing (hobbywing fun fly 150 a-hv-8s esc) with out a manual.
I need to know what the various wires on the input side do and where they connect into the receiver,
There are two servo leads , one short, the other quite long. I assume that the long one goes to the throtle on the receiver. Short one ?
Red and Black battery wires are obvious. I suspect that the break in the red wire is for spark suppression.
Off of the battery plug are small diameter wires going to a UBEC (input 8v ~ 42v, 3-10 lipo). It has a plug to control output to 5 or 6 v. Should I use 6v? Also has an on/off switch. I assume that the switch is on/off for the whole radio system. The output side has a choked cable with a 2 wire connector.
So whats going on here? Do I plug the 2 pin into an unused receiver port or can it be Y'd in on a regular channel. Van it be Y'd in with the throtle?
Now the other question. Dual fans. Y the throtle cables. Y or use only one of the power cables?
Plane is a TSR-2.
Plane is a TSR-2.
