Pandora ESC Problem
  • Spool
    • May 2014
    • 8
    Pandora ESC Problem
    Having a problem with my new Pandora...have it all together and wanted to check the setup, but once I plugged in the battery and linked my Tactic TTX 650 to the receiver...the ESC just started beeping non- stop. Throttle was at zero...or actually, according to the transmitter screen it was at -100. Could that be the issue? Not sure how to get the radio to show zero percent throttle with the stick at the bottom. Has anyone else run into similar ESC issues with the Pandora? BTW, this is. Y first electric plane, so if there are ESC setup or calibration sets that need to be completed, please fill me in... The manual is less than complete in regards to electronics install and setup. Thanks!
    Spool
  • Hippie 64
    • Feb 2014
    • 1049
    • Gaffney , S.C.
    Re: Pandora ESC Problem
    Check to see if you need to reverse your sevo on transmitter
    But Crashing is Landing
    • Spool
      • May 2014
      • 8
      Nope, that was good to go...but I'm an idiot and had my rudder and throttle inputs plugged into the wrong channels on receiver. Doh! Glad the ESC was smarter than I was...
      • Spool
        • May 2014
        • 8
        Hello Starcop...got it all sorted after I put the servos I the right receiver channels! No problems now...thanks!
