any new pro admiral batts coming out
pro admiral
Tags: None
Re: pro admiral
1600 to 1800 may be hard. It is possible to get higher C ratings out of larger batteries but much more difficult to get higher C ratings out of smaller batteries. The Admiral 1600 to 1800 may be maxed out already but I will ask the manufacturer. We always want to make sure our C ratings are truthful. Unfortunately many C ratings nothing more than fiction. Some 1300mAh to 1800mAh batteries have 70C on the label. Our manufacturer tells us that is impossible though many of their OEM customers go ahead and ask them to put that on the label. I'll do the math
1800mAh = 1.8Ah
1.8Ah x 70C = 126A continuous
There is no possible way a 1800mAh pack can sustain 126A without puffing, blowing up, or going bad.
I will ask the manufacturer but I'm fairly certain (based on past conversations with their engineers) 30C to 35C is about the max sustained C rating modern technology can achieve from a 1600 to 1800mAh pack. The bottom line is that a higher C rated pro pack may not be possible in this size and we want the C ratings on Admiral labels to be truthful.Comment
Re: pro admiral
Yes, floats on the way. I personally love to fly sea planes so I will make sure to get floats for any planes where they are available. At first I stayed away from the floats for this plane because they are technically for the Supercub and I was not sure how the blue decals on the floats would look with the red plane. I've since seen some pictures and it looks great so we will go ahead and bring in the floats!Comment
