motor wont turn
  • rusted & busted
    • Jul 2014
    • 6
    motor wont turn
    has any one had motor problems with the pandora? mine wont start.
  • Baron
    • Feb 2013
    • 231
    Re: motor wont turn
    Are the servos working? It sounds like you have not programmed your ESC. Is the ESC's wire connection into your receiver correctly positioned into the number 3 slot and not inserted upside down?
    If you have Futaba radio or Tactic radio, you need to set the throttle on reverse, and then program it. Let is know if you get the motor to run. IF not please call Motion RC and they will be able to help.You can view Motion's tutorial video about arming an FMS brand ESC. It is very simple to arm the ESC and this might help.
    http://www.motionrc.com/video-tutorials/
    • MDBassPlayer
      • Jul 2014
      • 3
      Re: motor wont turn
      +1 To what Baron said. I friend of mine and I both have them as our first planes and it took us watching the video to get it right and reversing the throttle channel as we both have Futabas.
        • 7333
        Re: motor wont turn
        With my Spectrum DX6i, I have to retard the trim on the throttle all the way, then give it a bit of throttle, it will start, then move the trim back to the neutral position. Then all is well, til you change the battery, then repeat...
        • Lon
          • Jul 2014
          • 1201
          • Miles, Iowa
          Re: motor wont turn
          Hmmmm...The Pandora is my first plane too. Running with the DX6i and AR6210. Have not had any issues. Have at least 75 flights under my belt with it. Last 25 flights in the low wing tail dragger configuration...
          Lon
          • rusted & busted
            • Jul 2014
            • 6
            Re: motor wont turn
            thank you for input ,i had to program the esc duh.i am new to r/c planes lots to learn thanks r&b
