the bec lights up. All control surfaces work correctly. but the motor wont arm. it has a start up tune then beeps once,twice,three times. lights on the wing flash. any ideas?
freewing FA-18 bec
Re: freewing FA-18 bec
Sounds like throttle stick or possibly throttle TRIM not at complete zero.
Presuming you did of course not forget to bind the Rx to your Tx first. Do that, & perform a range check? -
RE: freewing FA-18 bec
Just a reminder - in testing to sort this out, if you can, remove the fan, else cover the air intake with something that won't suck in. You don't want your airplane leaping across the room when it comes alive.Comment
WintrSol is so correct! I made the mistake of reversing throttle, inside my shop, yet. My plane instantly went to full throttle. Need I say how ugly that was?!!! The DoctorComment
