admiral rx600sp i
  • planeguy71
    • Oct 2017
    admiral rx600sp i
    I recently purchased an RX600SP for my Dynam Sbach. I tried to bind it to my DX6i and all servos worked but no throttle and the ESC beeps rapidly. I normally use a Spektrum AR600 with a Detrum iStone Pro gyro with no issues. I’m not sure what Im doing wrong. Any help would be greatly appreciated. Thanks in advance
  • ryramZ
    Pilot Ryan
    • Dec 2012
    • 814
    Try to move the throttle trim down.
    • doctormike
      HobbySquawk Moderator
      • Oct 2013
      • 1260
      • Santa Fe NM
      Or, maybe, calibrate your throttle. Take your prop off. Turn on your Tx. Put the throttle full up. Plug in your battery. Let it beep. Pull the throttle down. Let it beep. It should be ready to go. If not, do what Ryan said. Good luck. Doc
      • planeguy71
        • Oct 2017
        Thank you for your help gentlemen!! I tried it both ways and they both worked!!
