Everything works well on the receiver except there is no horizontal surface (only up sloping surface) where i mounted my receiver. When I hit the bind button (auto level) the plane recovers but is heading downwards. Would like to reset the level of the receiver so it flies level when hitting the bind button. Tried cycling the bind button 8 times upon power up as per the lemon receiver manual to no effect probably since different firmware is on it from Motion RC. Any other ideas on how to do this?
Admiral RX600 SP resetting level
If your Elevator is not correcting properly then you may just need to Reverse it by moving the Dip Switch J2 and see if that works. Remember you also need to have the plane sitting in a non level position first when testing the Auto Level. As you hold the Bind Button in and then at the same time move the plane back to level and you should see all control surfaces go back to a Neutral Position. If you continue to have issues then please watch the video shown at this Link and you can also contact our Warranty Dept at the other Link. https://www.motionrc.com/collections...izer#video-tab https://support.motionrc.net/open.php
.png)
