Setting up a Dynam SR86A rx to a Dynam6c in a Dynam Turbo jet
  • Mrdronenut
    • Mar 2018
    • 27
    Got a little problem. I've found out that if i put ANYTHING in aux 1,that the auto recovery mode will not work. I either lose landing gear,or flaps. I don't want to give up my flaps,which I've got set up on sb,the only 3 position switch.
    I'm using sc for normal and auto recovery and sd for d/r.
    Short of buying an 8ch tx,does anyone have a solution?
    The SR86A is set up so that aux 1 is f/c channel,so,if i put flaps or gear in it,all that works in the gyro is "normal".
    Help. Any way to mix anything?
