Controller
  • Controller
    What's the best controller for a beginner/intermediate with room to grow that will work with AS3X?
    As3x is stability system. Assuming you want a controller that will with DSMX which is the original for HH and eflite bnf planes. If you are going to run just dsmx any of the spectrum controllers are great. A simple 6 channel can last you for s really long time. I like 8 channel it better giving you ability to control more features
      Spektrum radio systems for AS3X/DSMX
      Minimum recommended is 6 channels (whichever version DX6 is current)
      More channels means more possible controls and more mixing options.
      I'm not current on the Spektrum radio line. I use their high end DX-18 system (which is probably more radio than you want)
      Telemetry capable radios cost more and the telemetry is a marginal value. Its a "nice toy" that can give you some helpful information and it does some data logging for people who like to experiment and find out what the real results are. I was disappointed that the voice warnings are barely audible with any glow power model flying in the area.
      For over 25 years of flying RC, I never used more than 5 channels. Then I discovered computer mixing functions.
      You want to buy enough radio capability to last 3 years. What do you expect (or want) to be flying 3 years from now?
        Don't go cheap on your transmitter. Get a Spektrum, after the sale service is outstanding. The DX6e should be your minimum choice. I personally find the DX8 does everything I need.
          Thank you all for your responses! Just for reference, which aircraft, from MotionRC are 8 channel? Should I really spring for all 8 channels? If not, should I go for the Dx6e including the transmitter in case I get a PNP aircraft?
            Probably the best response to your last inquiry falls directly with the last sentence in the remarks that fhhuber gave you.
            "You want to buy enough radio capability to last 3 years. What do you expect (or want) to be flying 3 years from now?" ;)
              I think that's good advice, however, I guess my response is that I don't know what I'll be flying, I want to make sure that I buy enough controller to keep my options open.
                Then I'll have to recommend a minimum of a 7 channel radio. 8 if you are thinking of FPV.
                You can use 5 channels on most f the 4 channel models. Using 2 servos for ailerons, you can use 2 channels and get options for trimming and "differential aileron throw" which help in fine tuning the aircraft. Then I like cutting in the flaps and adding the servos on models such as the Dynam P-51 (original version... I heard a new version already has the flaps) that changed the 5 channel model to potentially using 7 channels. Add a bomb or belly tank release system, now you can use up 8. Or if going FPV, the head tracker system uses 2 channels. Now that "5 channel" model can use up to 9 channels.
                Then there's advanced models. I'm working on a 107 inch span Me262 that uses 8 servos for flaps... It could potentially benefit from a 24 channel radio.
                  Thank you! Is there any benefit in purchasing the radio with the receiver or should I just wait until I need it?
                    I've been at this rc plane thing for a little over a year , started with a 4 channel ... went to a 6 now I have a DX 8 Spektrum. To do it over again i'd start with a 8 channel minimum
                    Throttle ,Ailerons, Elevator, Rudder, Retracts, Flaps, Gyro . Bam ...7 channels
                    • #11
                      There is usually a cost savings to buying a TX+ RX package. It used to always be a package of TX + RX + servos, but the "standard" servo is now not as commonly desired, so the packages have changed.
                      If you stick with the hobby, you'll eventually want a LOT of receivers. One per airplane in ready to fly condition plus a couple of spares (for the next planes you'll be building/buying or for testing/replacing questionable receivers)
                      • #12
                        I have only used 6 channel Spektrum transmitters. I have the DX6i the Dx6e and the DX6. I use the DX6i for my simulator and the DX6e as a spare. My radio of choice is the DX6 because of the voice feature. I use the Lemon receivers with stabilization because they are only $24 and have never failed me yet. They are compatible with Spektrum DSMX and AS3X. I use them in all of my aircraft. I doubt I will ever need more than 6 channels. If you fly electrics the voice feature is nice as you don't have to take your eyes off of your aircraft to see time remaining. I doubt you would hear the voice prompts with glow or gasoline. I would stick with the DX6 or the DX8 if you think you may grow into it. I have sent my various Spektrum Txs in for service 3 times and they have always been repaired for free, very quickly. Their customer service is stellar. Hope this helps.
                        • #13
                          Dx8 g2. Its a great radio. Love mine. Not much more than the 6. Stock lipo battery in my dx8 lasts all day. You will use more than 6 channels very quickly.
