Reset to factory settings on A3L
  • bpoates25
    • Jan 2015
    • 6
    I have the Hobby Eagle A3L, and have tried to reset to the factory settings but can't get it to. I press the button down and hold for over 4 seconds, and it continues to flash red and blue after I release the button. I never get two distinct flashes. I also would like to just set it up as a two position switch. I don't want 3D on it. I use a Futaba 7C, and when I assign it to a 2 position switch I just have the blue and red. I have no off mode. I have watched all of the video's over and over. Any help is appreciated.
    Thanks,
    Ben
  • bpoates25
    • Jan 2015
    • 6
    RE: Reset to factory settings on A3L
    OK I got the reset done, and figured out the 2 position switch for a Futaba radio. To cancel 3D, and only have normal mode or off I assigned the A3L to the 3 position switch on my radio. I then went to end point adjustment for that Chanel and flipped the switch to 3D mode. I then set the end point adjustment to zero for that switch setting. I now have normal mode, off, and off. Good to go.
