Tried to keep fpv set up affordable.
  • Skyboom
    Foam flyer
    • Nov 2018
    • 344
    • Chilliwack, British Columbia, Canada
    Because I'm on a strick budget, I ordered cheapest possible set-up. Includes the "Value-Trade-Inc FPV camera, 2.8 mm lens, supports 5v-22volt. PAL/NTSC.
    - Fosa FPV monitor 5.8 GHz, 7inch LED screen.
    - Wolfwhoop Q4 receiver 5.8 Ghz, 40 channel. with MMCX antenna connector.
    - Wolfwhoop T1 FPV ,5.8 GHz Whip antenna. (Q4)
    with shipping it came in under $156.00.
    As long as it works, It'll be fine for my Wing.
  • Skyboom
    Foam flyer
    • Nov 2018
    • 344
    This setup was a little more challenging than the Crazypony setup ( which is in the Batwing). This Wolfwhoop setup will go in the glider.( I would like to operate this system through solar cells) However still waiting for glider and solar cells (It's a long boat ride from China).
