tactic radio and eurofighter
  • tomme21
    • 21
    i recently purchased a e/f from motion and I'm having a few hangups getting things to work properly. i own a tactic 6 channel radio and receiver, I'm NOT using thrust vectoring so all of that is disabled. i did this on my last e/f with a 6 channel jr radio and it worked well, what i want to do is this: make the canards operate only as elevators, I've got the ailerons working properly as ailerons and elevators but the canards don't respond as elevators, just ailerons .whats the secret on a tactic to do this, if it won't do that, how do i get elevators to match with my ailerons ? thanks
  • XF-15DCC
    • May 2015
    • 164
    • Bristol CT
    RE: tactic radio and eurofighter
    I have a 850. Would you have to go in you transmitter and work with the channel assignments? Hope that helps.
    Off with one helluva roar!
    AMA 1085465
    • tomme21
      • 21
      i have no idea what you said, and how does this even begin to help me, you hope what helps???
      • XF-15DCC
        • May 2015
        • 164
        • Bristol CT
        Yea, sorry about that football in the background........
        Go to your manual and look at the channel assignments section. This is where you can assign the channel to perform different things (if I understand this correctly). If you have this option on the TTX650, you should be able to assign the canards to operate the way you want to.
        Page 17
        http://manuals.hobbico.com/tac/tacj2650-manual.pdf
        AMA 1085465
        • tomme21
          • 21
          i have the manual. it actually came with my radio, but, like i said, i cant figure it out, i just cant get how to make the canards work just as elevators, nothing else just elevators, just cant seem to make it work. thank you for your time to try to help, its appreciated!!~
          • XF-15DCC
            • May 2015
            • 164
            • Bristol CT
            I'll mess around with my transmitter and see what I can find. Have you seen this? Last video is how to program the 650. Maybe it is there.
            http://www.motionrc.com/tactic-ttx650-6-channel-transmitter/
            Kevin
            AMA 1085465
            • tomme21
              • 21
              yes, but it does not explain how to make canards work as elevators only on a eurofighter
