OK, stupid question #500.
I've been using a DX 6 gen2 for about 7 years and just noticed in the upper left hand corner of the screen, the DSMX indicator. I know this shows up when it is bound to a receiver, but just to the left of it when bound to a plane is a 4 bar indicator like you have on your cell phone for signal. When I'm close to the bound plane, all 4 bars are up. As I get further away, they start to drop off and about 50-100 feet away there is only a line. I have over 25 planes with a spektrum AR636 in them and at first I thought it meant that I was losing signal to/from the receiver. Turns out it's like that on all my planes and they still fly fine even as I get quite far away. Have to admit in over 500 flights I never looked at it while flying, but just happened to the other day.
Can't tell if it's always been that way or just started to happen recently. Eventually going to a DX8 when I finish my next bank heist, but for now just wondering if I've got a potential problem. :fearful: Of course the manual is totally useless on this issue.:face_with_hand_over
On my telemetry menu, I have 12 items, most of which read "empty", except 11 is RxV and 12 is Flight Log. I have changed #1 to AS3X (which defaults to empty also), and this allows one of the in flight screens (accessed via the right roll bar) to show gains in all axes. I use this to change gains (if programmed to absolute instead of relative) during flight. This screen, along with the flight log screen and RxV screen can only be accessed via the roller when a 636 receiver is bound and connected. Mostly, I only check that AS3X screen before taking off to make sure the AS3X is working and giving the correct values in each of the 3 flight modes I have programmed (1: fly around, 2: take-off flaps, 3: landing flaps). It seems as I move away from the plane further and further, the values in the screen go from populated to blank as the bars go away!
