Hello.
I recently bought an E-Flite Timber 1.2 PNP. I have a Tactic TTX650 transmitter and I installed a Tactic TR625 receiver in the plane. The plane flies good. But I can not figure out how to get the elevator to mix with the flaps with a three position toggle switch. I had no problem with my elevator and flaps with my De Haviland Beaver, when I hooked that up with my Tactic transmitter and receiver.
The problem can be described as: when I put the 3 position flap switch into position number 1, the flaps move down just a little - where in actuality, they should not move at all, as that is the normal "flaps up" position. Next, when I move the flap switch into position number 2, the flaps return to "normal up" position. Finally, when I move the toggle switch to position number 3, the flaps drop to full deflection.
I am about at my wits end in trying to figure out as to why this is happening and how to fix this so the flaps mix with the elevator when the three position switch is toggled to the desired positions. If you have any thoughts at all, it would be much appreciated.
Thank you very much.
Jim
Jim
