WHERE TO CONNECT THE nAV LIGHTS
  • Misgiuded Child
    • Sep 2019
    • 5
    I JUST GOT A DYNAM F6F HELLCAT 1270MM RTF. IT CAME WITH FLAPS AND LIGHTS. I HAVE THE FLAPS PLUGGED INTO THE AUX1 CHANNEL ON THE 6CHANNEL RECEIVER BUT NO WHERE TO CONNECT THE LIGHTS. DO I NEED ANOTHER Y HARNESS TO CONNECT TO THE AUX1 CHANNEL ALONG WITH THE FLAPS OR JUST UNPLUG THE FLAPS AND USE AUX 1 FOR THE LIGHTS
  • Prowler901
    • 940
    • Gunnison, CO
    You can connect a Y-harness to aux1. Then connect one side to your flaps and the other to your lights.
    • Ableleader
      • Oct 2019
      you can also plug them in where the bind plug goes the center is always positive and the ground is farthest away from the signal or white wire
      • Misgiuded Child
        • Sep 2019
        • 5
        THANK YOU ALL , I USE ANOTHER Y HARNESS AND THE LIGHT AND FLAPS ARE NOW IN THE AUX1 CHANNEL.
