Now that the Rotorscale Heli series is including a microbeast flybarless controller, I thought I would post a brief tutorial and my setup values for the 450 UH-1 Huey.
First off, I wanted to point out some excellent resources for getting started with the setup. The BeastX has a very thorough quick start quide: http://www.beastx.com/download/manua...tart_V5_EN.pdf and wikisite: https://wiki.beastx.com/index.php/Ma...FblV5:Intro/en that walks step - by step through the programming.
Between those 2 sources, you should be able to answer most questions on the setup
One other note is that I had the optional Bluetooth Module on hand, so I did most of the setup through that system. It does make things quicker to adjust, but certainly isn't a must-have. Some of the screenshots that I post below will be from the App.
1. Model Setup: The first step to setting things up is to configure your TX for helicopters. Set up a new Helicopter model and set Swashplate type to "normal" or "single servo 90". This will make your collective pitch channel free of any servo mixing. Make sure there is no subtrim or mixes in the setup. You should also configure one of your channels for setting tail gain at this point. I would also recommend programming a throttle cut switch an this point.
2. Receiver Setup: The beastX has a few options for reciever setup. You can hook up a single Satellite RX direct to the unit, however this doesn't give you any redundancy. I recommend using either a normal RX (I used a spare Admiral 10 channel w/sat) or a srxl receiver. Wiring was configured as shown below:
The BeastX defaults to the "standard reciever" config, so no special setup was required there. If you do need to change your RX type, detailed instructions for that are here: https://wiki.beastx.com/index.php/Ma...eceiverType/en
3. Mounting and Orientation. I mounted my BeastX on the gyro tray of the Huey wires facing aft. To tell this to the receiver, you'll need to power up the system. Make sure your blades are removed throughout the initial setup in case of inadvertent power-up. It will take a few a few seconds to intialize the controller. Make sure the aircraft is left stable throughout this initialization for calibration of the accelerometers. Then, hold down the programming button for 2 seconds until LED "A" is steady. This means that you are in programming mode. Move the Rudder stick left/right to change the color of the "status" LED to correspond to the device's orientation. In my chase that was Red for flat, wires aft:
4. Servo Frequencies: Hitting the setup button again will advance the small LED to Menu "B". Menus B-D can be adjusted as shown below:
I set all of my servos to 200/270 Hz and 1520 us. The servos are technically spec'd to run at 333 hz/1520us, but apparently can get a bit hot doing so. The lower refresh rate should relieve this load and be easier on the servos.
After setting this up, go ahead and plug your tail servo lead into the CH4 slot on the BeastX
