Admiral rx600sp réglage
  • Mady74
    • Apr 2020
    • 19
    Bonjour à tous
    une question, pour le réglage l’avion doit-il être à plat? J’ai deux avions avec roulettes de queue donc très incliné
    faut il qu’il soit horizontal ?
    merci pour votre aide
    Good morning all a question, for the adjustment of the plane should it be flat? I have two planes with queue casters so very tilted does it have to be horizontal? Thanks for your help
    • 8814
    Like most gyro equipped RX's, they must be quite flat, either on their bottom or on their sides, but you must tell the device how it's orientated. The instructions should tell you how to do that. If the plane sits at an angle on the ground, you should raise the (tail) plane and prop it that way for it to initialize so it can determine what "level" is. It must also be pointed in a certain direction so it knows which is front and which is the rear.
    • Mady74
      • Apr 2020
      • 19
      Merci pour cette réponse
      pour les gains mieux vau t’il les garder à 50% pour le premier vol?
        • 8814
        I would start with the gains at about 25% and go up in very small increments. If they are fast planes, 50% may likely cause a severe oscillation at speed.
        • Mady74
          • Apr 2020
          • 19
          Merci pour tes bons conseils
          je vais régler progressivement les gains
          merci encore 😉🙏
            • 8814
