Calibrating ESC
  • Cactus Bobby
    • 37
    Calibrating ESC
    I have a Spektrum dx9 and moved throttle stick to position LLVR. This is the roller switch left hand side back of transmitter.
    works fine. Only problem I cannot calibrate ESC with throttle anymore. I believe esc isn't seeing 0 value on throttle.
    help.... if you wonder why I did this I have a Tremor on left hand.
    • 8835
    "0" throttle on a Spektrum is -100 and goes to +100 at full throttle on the stick. For those who lower the throttle trim tab to the lowest position, then "0" throttle becomes -129. I'm not familiar with this "LLVR" although I have done throttle calibration for someone else on their DX9 using the stick and had no problems. I would suggest you go to the TX's monitor and see what the range is for your "LLVR" from lowest to highest. If it's NOT -100 to +100, then that's why you can't do a proper throttle calibration. You may have to go into your servo travel menu and make the necessary changes.
    • Cactus Bobby
      • 37
      For some reason, I did not receive this. Thanks for the input.
