Spektrum NX6 Charging issue
  • expertbasser
    Pilot 35+ years
    • Dec 2020
    Originally posted by Crawfjams
    Gentlemen I just purchased NX6. Trying my first charge , I plugged it in and it seems to be charging. How will I know when it is fully charged. Green charge light is on now.
    the charge light will go out
    • Tigerrobuk
      • Dec 2021
      Spektrum NX6 problems. Bought TX last spring 2021. All Ok initially then charging problems started. Found if I removed battery and replaced it, charging would begin OK. However having just done this and put battery on charge found that the charge did not work so removed cable from back only to find the female end into which the charging cable went completely disappeared into the TX itself!
      Anybody had this problem and how was it solved?
      • Sureshot
        • 235
        This problem was solved in one of the firmware updates.
        Have you updated your TX to version 3.06?
        That is supposed to fix the problem.
        Steve
        • Multi 103
          • Mar 2022
          Hi
          I also bought a new NX 6 2021 and have the same issue on charging, i unplugged the battery and the green light came back on, but i se that it’s not a permanent fix. Does anyone know if there is a permanent fix ?
